2nd Gen GE8 Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-ForumThreads discussing engine mods/swaps/tuning for the 2nd generation GE8 Honda Fit.
Welcome to Fit Freak!
Welcome to Fit Freak,
They reflash the ECU to tune the fuel and ignition system to match the car, tuning includes released speed limit cut and rev limit cut, too. Oh and also close loop checking. There's no worry about honda warranty claim as they do not cut any wiring. They just open the ECU and connect the pin to read and write the data. It take around 6 hours, because Honda's ECU is sealed with a silicone that is hard to open. They have to use a special chemical to open it, but it does not harm the ECU. It takes at least 3-4 hours to open it, after that they start to read and write the ECU to match the engine number, chasis number, immobilizer code and other technical stuff.
They also give a full warranty.
Watch this. It's the same thing, but the company dyno tested before and after. No problems at all. Just expensive, about $400 US. The only problem is opening Honda's ECU unit correctly on the GE Fit."
When all is said and done, we should have a way to reflash the ecu without removing anything from the car. What they are doing is a serial solder to access the eeprom directly. This has been done with piasini tools as well. I'm hoping we'll have something to test with soon.
Nothing much right now. I have been working with Epi to get the logger working with existing PID's. Once that is functional we would be able to locate additional PID's / parameters to log. It also supports many wideband o2 units.
I will check with Colby to see if there has been any progress on the kernel. I know he's been pretty busy incorporating the standalone SD card logging to the OP 2.0.
hi there, anyone has the drivers for OP2.0 to work with HDS?
can you please send to me? I would like to trick the ECU for and update as well. And also what kind of software needed to trick the ECU to read the wrong code?
You will need a "Rev D" cable for it to work with HDS. If you look on the back of your OP 2.0 unit check for Rev C or Rev D. I cannot release any "tricking" firmware at this time as we are still in testing.
Hi there
Thanks for the reply.
Perhaps we can do something on the Fit. I have an idea to share on the tuning the Fit
It seems very positive with the trick to create an update for the CM Update
I will PM you the details so we can share more to release a tuning option
Totoro and I have been working on something for the Civic and it may pan out to help with the FIT. The kernel for EcuFlash is still in progress. We're still making progress but it's slow!
I don't know how this stuff works, but I do know that since my re-flash the car pulls away much faster and on an expressway the RPM seems much lower at a high speed.
This is the amazing part, I'm getting an extra 2-3 km/L around the city and much better on the expressway.
If anyone out there has a JDM 2009+ Honda FIT, can you please grab the ECU Part # off of the label on the ECU for me? It will be something like 37820-XXX-XXXX
No news on the kernel yet. I have been successful with cross-market flashing so far with some tricks. Still working on various testing and waiting on the kernel for a full dump. I am in need of the various market part #'s for the 2009+ FIT's.
I am glad Honda stepped up the plate for an update for that. I don't know if that will help ev8siv3 with anything but thanks for the info. Can we just take this in and they reflash?
__________________
FS:
7g Accord I4 Eibach Pro kit springs - Never used
7g Accord Ingalls rear camber kit - Never used
2009 Fit M/T P33050 37805-RP3-3050
2009 Fit M/T w/navi P33060 37805-RP3-3060
2009 Fit A/T and A/T Sport P33070 37805-RP3-3070
2009 Fit A/T Sport w/navi P34050 37805-RP3-4050
Now I just need a copy of the 37805-RP3-A050-M1.rwd file to update. Any other owner could simply make an appointment with Honda and take a copy of the TSB in for free service.
