2013 Honda Fit - Gear shift indicator light, how do you change it??
Old 08-23-2014, 08:35 AM
stacey88s's Avatar
I need to change out that light, and have have been searching online with no such luck on how to get to the bulb.
I have an older Civic that I am able to pop the area open easily to get to the bulb, but for the life of me, I can't figure out or find out how to get to the Fit's bulb.
This is for an automatic.
Old 08-23-2014, 10:43 AM
Steve244's Avatar
Are you talking about the floor-shifter? I don't think it's illuminated (at least it's not on an 09 Base).
Old 08-23-2014, 04:09 PM
stacey88s's Avatar
Sorry, is this area called something else?
The light behind the P R N D S
Old 08-23-2014, 04:46 PM
xxryu139xx's Avatar
look at collegehillshonda and pull the pdf/video on how to install the OEM armrest. It will show you how to pull the center console/shifter. from there the oval with the gear letters will be exposed and you should find a screw or two remove. there is a bulb under there. just twist counterclockwise and pull it off.
p.s. if you are switching to LED. make sure you get a white LED. i put a blue LED in there and now u can't see P & R since it's filtered out.
Old 08-23-2014, 06:31 PM
stacey88s's Avatar
Funny thing, during my research that video did come up, but I thought it'd be easier to do instead of taking that whole middle console up so I didn't even try it.
But thank you for confirming! Done in 10 minutes.
Mahalo!
Old 08-23-2014, 07:14 PM
xxryu139xx's Avatar
aloha to u too
Old 08-24-2014, 10:43 AM
Steve244's Avatar
Oh yeah, it is lit! I've ignored it for 5 years as it serves no purpose in a darkened interior: you can't tell which gear is selected as there's no tell-tale on the selector. I always just look at the dash board indicator lights to know I've hit the big D.
Old 08-27-2014, 06:35 AM
Li2099's Avatar
Haha just realized too that it's lit.
Old 04-25-2016, 10:53 PM
excelwithme's Avatar
What bulb type for gear shift indicator light?
Just wanted to find out what is the replacement bulb for the Honda Fit 2010 gear shift indicator light.
Sujeto
10-20-2016 05:52 PM
Getzbie
12-31-2013 01:22 PM
MonstaMatt
06-09-2012 07:54 PM
Black01
01-08-2011 10:56 PM
WhiteNoise
03-29-2009 10:26 PM
Quick Reply: 2013 Honda Fit - Gear shift indicator light, how do you change it??
