Passenger windshield wiper
I would think a larger wiper on the driver's side would wipe up past the glass on the top. And if you got one that didn't, the extra inch or so is so not going to make up for the 8" of clear space you get on the passenger side of the windshield with the other wiper there, IMO.
That being said, the passenger side wiper is really weird. The whole wiper situation on the Fit is a little odd. But it gives it character lol.
Edit: Now, I know that a lot of people run around taking off the rear wiper, but I would actually like to put a larger blade on *that* one to clear more of the rear window. I wonder if that's possible.
I have a concern with the passenger-side front wiper, as well. Its path of travel stops right dead center in front of my field of vision and leaves a smudge that's hard to see through (it goes away in a second or so, but with the wipers on a faster setting it will be constant).
I took mine off and replaced my 28" driver's side blade with a 32" blade from an RV place near me. I use rain-x and rarely drive my Fit with anyone else in the car so the small swath of uncleared area doesn't bother me. It does present a small issue with frost but I scrape that area an extra second or two and keep going. You pry off the rubber cover, remove the 14mm bolt, rock the blade back and forth and it will come off. Put the 14mm bolt back on and cover it with the rubber piece.
Voila, right wiper delete.
When I adjust my valves I'm going to see if I can get rid of the linkage so the right side doesn't turn.
b
b
have any of you guys noticed that at idel the passenger side wiper arm vibrates?? or is mine the only one plaged w/ that? I have also noticed that when the wipers are on and you put the tranny in reverse that the rear wiper starts. Does it work like that w/ the manual trannys??
little different
Location: Winthrop Harbor Illinois/ Presque Isle Wisconsin
I took mine off last april
it works fine, I use aquapel (rain-x on steroids)
No visibility issues.
A picture and more details in this thread, I think page 2
https://www.fitfreak.net/forums/2nd-...ngs-maybe.html
The only thing I could think that may inhibit a change is if the top of the rear window isn't flat enough for the new length of wiper/blade to wipe sufficiently. If so, then adding a longer wiper/blade would be somewhat useless, obviously.
Let me know if you do it, and how it works out. I hate rear windows that do not get adequately wiped. It's like, why even have a wiper if some portion in your field of view is left largely uncleared.
I just bought my 2010 Fit and the passenger wiper also shakes while at an idle. What I did was lifted up the driver side wiper and then I lifted up the passenger side wiper. I did notice that the Spring on the passenger wiper is weaker than the driver side it seemed. So I was thinking if I could buy the stiffer spring and install it on the passenger side wiper it would stop... If anyone has fixed this problem please let me know how, it's irritating.. lol
I just checked the rear wiper which, at vertical position, comes within less than a half inch from the top of the rear glass, and clears a Sport spoiler by the same amount. Also, the last 1.5" of the glass is blacked out, so a longer wiper would have no effect in that dimension, and only marginal impact horizontally.
My complaint about the rear wiper is that it appears to have been designed for JDM, and Honda didn't bother to change the geometry for the rest of the world -- the pivot should be on the left, not the right, for the driver's view. Unfortunately, not something that can be changed by the end user.
shawnshank
10-19-2013 04:45 AM
Howard Lester
05-04-2005 11:16 AM
