2011 brand new Honda Jazz (Fit) engine noise
2011 brand new Honda Jazz (Fit) engine noise and vibration
Hey there,
I just bought a brand new 2011 Honda Fit (Jazz as its called here) but i didnt imagine the jazz engine sound like this..
Here is the link for it : YouTube - ‪VIDEO0004.3gp‬‏
Well first of all im trying to find an answer for this situation like about a week now mostly checking the old topics on fit freak, but i came up with nothing only its kinda normal and doesnt give harm.
Am i right?
Also i gone to my service at 2nd day i bought the car, as i thought and as you guys also can imagine it they say 'its normal injector noise'
Also i checked 2 more Fits there and they have kinda same noise too! So i accepted it..
Any opinions on this situation? Should i change my petrol station or maybe the oil at 1000km service time?
Thanks for reading.
Am i right?
Thanks for reading.
Hey there,
Am i right?
Thanks for reading.
Am i right?
Thanks for reading.
Here in the US, Honda does not recommend changing the factory oil before the first scheduled change according to the car's electronic maintenance-minder. In some of our cars this is 16,000KM (10,000miles) before the first change. Apparently there are additives in the factory fill to aid break-in. I'd go by whatever your owner's manual says. There may be different standards where you live.
Drive it easy for the first few thousand KM and enjoy it. It's a good car.
Well my Fit (Jazz) came to 1200 km. I kinda accept the engine sound that i mentioned in this thread before (still i have some concerns about it but doh..) but now some other thing is confuse my mind;
-The idle RPM of my car seems to be at 600 or so cause the pointer in the gauge is a tad over the 500 RPM notch.
So when the car is at idle i can feel a bit of vibration. Is this thing cause of low idle RPM ? Or is it normal?
-Another question is should i change the stock filter with K&N inbox filter for better performance?
Hope to get some answers, thanks for reading
Mine does the Idle thing that yours does. sometimes feels a little rough and like the idle is a little low.
as for the K&N, from what I understand the computer over time will counteract the power benefits that the K&N will provide in order to maintain a high level of fuel economy.
~SB
~SB
I've never had a vibration at idle. that usually signals worn motor or transmission mounts but that can't be it since you barely have any kms on your car. I'm not sure where my car idles (I'll have to check) but it's never been lumpy.
To reduce my FIT' engine noise... I tried to keep the rev low with gentle acceleration, stepping on the foot pedal just like stepping on egg shells.
One thing I noticed when I upgraded from 2001 Accord to 2010 FIT was the FIT only required a very light touch on gas pedal as it is a drive-by-wire set-up, unlike my old Accord that needed a lead foot to achieve the same effect.
When I first drove my FIT, my lead foot tend to rev up the engine unnecessarily increase noise and using more gas
Another thing is the when i opened up the hood i can see clearly that the engine vibrates at idle. Is this normal ? Like its shaking.
(I will put up a video on this later too.)
Is this thing normal or not?
Skip the K&N (IMO). There are threads here about excessive oiling causing problems. The Honda filters only need to be changed every 50,000KM depending on local conditions. Unpaved roads/dusty conditions will require more frequent changes. Resist the temptation for too early changes. A soiled filter actually does a better job at filtering and will not reduce fuel efficiency (but may reduce power a touch).
On vibration, I'd pull in to your friendly Honda service bay and ask those folks. Mine vibrates slightly with all accessories turned off (it increases RPM when, say, the headlights are turned on, and the vibration goes away). It idles slower than most 4cyl engines so some vibration is normal.
I saw those threads on K&N oil affecting the MAF sensor but i guess -also alot of peaople thinks this way- the oil leak to sensor and so is mostly after the cleaning process of the filter?
As for the engine vibration, i really dont want to go service cause they are always saying the same thing 'NORMAL' on most of the issues... This really annoys me..
I will post up a video in a few on this.
Yes, the cleaning process involves re-oiling the filter element. Too much oil is a problem. I think the way it comes new is OK. I don't think there is an advantage to using one.
