Safe to remove door edge guards?
Old 08-07-2011, 09:40 PM
SimpleFit's Avatar
I bought a CPO 2010 Fit Sport a few months ago, and it had these door edge guards already installed.
They don't look that bad, but I'm thinking I like my Fit would look better without them. I'm very careful opening my doors, so it wouldn't be something I'd miss.
I was wondering if anyone here knows if it's safe to remove them, or how to remove them?
Edit:
Here's a link to a page showing exactly what door edge guards look like, in case you're not familiar with them.
Just worried about messing up my paint.
Thanks
Old 08-08-2011, 07:00 AM
Chad T's Avatar
Those should pull right off. They might leave a little glue behind which you should be able to remove with some WD40 or other mild solvent.
Old 08-08-2011, 10:27 AM
malraux's Avatar
I would recommend not pulling straight out from the paint surface, as that's the most likely way to pull the paint off (not that I would worry about it in this case). That is, start at the top and pull straight down rather than pulling out.
Old 08-08-2011, 12:40 PM
madsedan's Avatar
I removed mine the weekend I bought my 2010, looked like crap and mine were also around the wheelwells. Every dealer in my area installs them on every new Honda as part of a "care package" where they do that with nitrogen in the tires, and tint the windows and puts a $1,500+ add to the sticker, dealer profit item.
I gently pulled mine off starting at one end, then using goof-off and a microfiber I removed the adhesive.
I did it at the end of the day when the car was 100 degrees, makes it easier to remove.
Car looks so much cleaner once its off.
Old 08-08-2011, 01:47 PM
sooznd's Avatar
warming the glue up a bit with a hairdryer might make removing easier
Old 08-08-2011, 05:21 PM
^^ yah you can do that or just pull on it on a sunny day if you want. ive remove those moldings on previous cars. they are ugly for sure.
Old 08-08-2011, 07:56 PM
Edit:
Thanks
Pull gently - start from one end. A few hours in the sun is easy to find - helps. All will be fine.
Old 08-09-2011, 10:48 PM
SimpleFit's Avatar
Thanks a lot guys!
Some great answers. Especially heating it up.
Will try removing them this coming weekend and post results.
Cheers, SF
Old 08-15-2011, 01:16 AM
SimpleFit's Avatar
Update: I removed the guards yesterday. It was a little time-consuming (40 min) removing all the leftover sticky tape, then using goo-gone to remove the remaining adhesive residue.
But now my Fit Sport looks sportier
I noticed I have the same kind of black edge trim along the wheel arches.
Do you guys with Fit Sports have this too?
-Or was this part of my dealer's edge guard add-ons thing?
Thanks
-SF
Old 08-15-2011, 05:04 PM
buckyfit's Avatar
Do you guys with Fit Sports have this too? -Or was this part of my dealer's edge guard add-ons thing?-SF
No, the edge guards do not come standard with Fit Sport. They are dealer addons.
Old 08-16-2011, 10:00 AM
^^ +1 wat bucky said.
it's a stupid add on some dealers put in there to make you pay more for your car. my cars definitely do not have them.
when i buy my car i test drive the exact car i purchase. i make sure the one does not come with these non-sense crap.
cnordt24
06-01-2017 04:16 PM
Namae Kana
07-28-2015 05:00 AM
Ameise
07-23-2015 03:51 PM
lowkeymods
08-03-2013 03:59 AM
bugzlyff
02-19-2012 02:58 AM
Quick Reply: Safe to remove door edge guards?
