Upgrading to a Fit
Upgrading to a Fit
I currently own a manual '02 Civic LX, which I've loved, but the repairs are starting to be more than the value of the car. The EPA mileage for my car is 33/39 and I was able to get 44 on a long-distance trip.
I love the look of the 2011 Fit, as well as the cargo capacity. I thought the base AT Fit would give the best gas mileage, based on the EPA estimates, but after looking through many posts and various websites, I'm thinking the MT Sport might be a better choice.
I'm really looking for the model that is going to give me the best gas mileage overall. Does anyone have any advice to offer?
Thanks in advance!
Thanks in advance!
The at is designed to be a bit better on the interstate; the mt should be a bit better in city driving. So it's all about what you plan to do. All that said, the two are close enough that it's hard to say that one is absolutely better. If you like mt then get that; the difference in cost of gas per 1000 miles is pretty minimal.
The Fit MT is one of the best in the business.
It makes getting all that is available from the engine and chassis fun and engaging.
The paddle shifters are decent, and great for people without a left leg.
If you want a highway cruiser go look at any of Toyota/Scion's blandmobiles. Or a new Civic for that matter.
Be prepared to wait for a new MT to be available at the dealership of your choosing though, they are sometimes hard to be found.
I appreciate the advice. I probably do 50/50 with city/highway driving, although I take the highway when I can. I am going to try to test drive a mt again before I make a final decision, but thought it had less pep than my '02 mt civic when I first test drove it.
Thanks again!
Thanks again!
The 2012 Civic is an absolute POS. Honda's build quality is going to crap.
Get the 5MT. The 5AT is rated better, but the car has to work harder to get up to speed, and acceleration is where the majority of gas is used.
And the 5MT is a lot more fun.
I'm not drinking CR Kool-Aid. CR writers aren't the only people who think that.
Go on Honda-Tech.
One guy works for Roadfly. He is the biggest Honda fanboi I've ever seen.
Even he says he'll never consider the 2012 Civic.
Go on Honda-Tech.
A lot of people are probably surprised Honda didn't do more for the revision, but its hardly a bad car... its a story about expectations and a different direction that Honda chose.
The car is hardly a POS... that you even choose to use such a description shows a total lack of being rational.
If you look at the 2012 Civic and say its a total POS, I'd shudder to think what you'd have to say about the Fit... which has a ton of cheap plastics, no soft touch anything, a bumpier ride than the Civic, cheap ass suspension, rear drum brakes, etc... if one wants to criticize the Civic that way, the Fit would be, I don't know, toilet paper for the POS?
The Fit has tons of room, utility, a lower price tag, but its nowhere near the Civic even in many ways, including the excellent fuel economy of the 2012 Civics.
As for the FIT. The economy difference is minimal between auto & Manual. The best thing you can do is find out what your average speed is on a regular commute. Mine is about 45 and I have a lifetime Average of about 38mpg. I've been as high as 44mpg and as low as 29mpg. My regular commute nets me in good weather around 41mpg as I don't have to use the A/C much. If your average speed is 60-70, then the auto will probably be better for you as you'll see the benefits of the Auto. (FYI Garmin GPS has an avg mph function - that's how I know mine) The Manual likes lower speeds and you'll see the benefits as well as a little more fun factor. The auto likes highway cruising.
The fit will likely have a little less pep than your civic. it had a 1.7L engine vs the Fit's 1.5 so less torque and your HP number will drop from the civic by about 15 I think both weigh the same amount. That said, the fit is a fun tossable vehicle. I went from a 270hp altima SE to the Fit and Can't be happier. doesn't have the power but it reminded me why I like to drive.
~SB
I believe the stick is the better choice for a fun ride.
Thanks for all the info. I'm going to test drive a m/t tomorrow as long as it is still there.
Specboy- thanks for the explanation of the engine differences between the Civic and the Fit. Just out of curiosity, do you have an auto or manual? Your mpg is impressive.
Report back.
Of course manual will get the better mileage. It is more efficient and loses less energy. Torque converter and a lot more fluid in the automatic means more losses and worse fuel economy.
I got 51-52 mpg on my 5 MT (by the meter). 47 (calculated). Rural roads though...
That's up to you. I couldn't believe them either until it became consistent. This was on my trip to yellowstone, WY from LA going by rural hwys through utah, idaho, etc. Here are some pics of the instrument cluster.
