JDM (non-LED) tails bulb socket situation
Can someone please help me? I bought my JDM tails from Japan and they didn't come with bulb sockets and of course my reverse lights USDM sockets are too small. I haven't been able to find anyone or any help on the forums on where exactly I can buy some bulb sockets for my install. I've emailed danny.pal99 about them but have yet to hear back from him. Until I do, would someone please let me know that there is hope for me?
Thanks, looks like the right PN too according to lings. Bulb is 7440?
Planning to put some led switch backs in my axis tails and I need to know what size those larger sockets are! I assume they're the same ones as the larger JDM base tails.
Check this thread too that just got bumped, for switchback lights they used a 3 wire socket (like the 7443). ---> https://www.fitfreak.net/forums/2nd-...3374-3157.html
Thanks for the info, the spot I'm putting the switch back into was originally the reverse light section. Basically the reverse light housing on my axis tail is going to double as a rear turn signal now. (Hence the switchback)
The v3 triton switchback sells in a 7440/7443 size so I guess I'm good either way!
The white portion will plug right into the reverse socket(the PN you gave me), while the amber will run in parallel with the axis led turn signal. (I'll just solder it directly into the wires. )
fg42man
11-17-2009 04:48 PM
Skibum
04-05-2008 10:49 AM
Jimmy101
09-13-2006 10:58 PM
