Sponsored by:
Sponsored by:
locking gas cap?
Old 07-06-2013, 11:29 PM
Cheyenne100's Avatar
locking gas cap?
just got my 2013 fit base recently and disappointed about the non-locking gas cap. thinking of getting a locking gas cap instead. any recommendations as far as brands and where to buy those? does honda sell locking gas caps for the fit? thanks
Old 07-06-2013, 11:48 PM
Hootie's Avatar
I believe the Honda Element locking gas cap should work. I have one on my GD and effectively its the same gas cap design (upon visual inspection, looking at the threads) as the one on the GE.
Honda Locking Gas Filler Cap (Element, Fit) - Bernardi Honda Parts and Accessories
Old 07-08-2013, 10:20 PM
Sticky Tires's Avatar
I just got one from amazon for less than $10.
Old 07-12-2013, 11:24 PM
thanks. did it ever give you the check engine light signal when you replaced the gas cap? how did you remove
tether and tether clip? (sorry i am not that technical)
Old 07-12-2013, 11:26 PM
cool. do you happen to know the brand?
Old 07-15-2013, 12:03 PM
Motorad P/N: MGC-791
The tether is held on by a clip. Just push the clip in with a small flat head and slide it out.
Old 07-21-2013, 11:00 AM
Bowbridge's Avatar
I put the one on from Benardi, the clip will come off if you push it in and slide it. The locking one went on OK, once I figured how to keep it locked; the key had to be turned to the right position or when the cap was screwed in, it wouldn't lock. Otherwise, no problems.
ketchup1
09-13-2012 09:42 PM
dryheat
03-30-2010 06:45 PM
SEAKAYAKER
12-17-2009 06:46 PM
Huggybear187
03-08-2007 12:37 PM
jdzz
07-16-2006 10:40 AM
Quick Reply: locking gas cap?
