Sponsored by:
Sponsored by:
Torque Specs
Old 07-10-2016, 09:32 PM
SunsetFit's Avatar
Anyone have torque specs for crank angle/position sensor?
Old 08-23-2018, 12:55 PM
upallnight's Avatar
Anyone know the spec for spark plugs?
Old 08-23-2018, 01:52 PM
If you are asking for the torque spec, it is 13 ft/lb.
Old 08-23-2018, 01:55 PM
eulogy's Avatar
honda recommends 13ft lbs
theres info on this site stating our plugs get loose magically...which i can confirm with my own car
denso recommends 15-22ft lbs...i did 20ft lbs on new plugs....3rd plug was i tiny bit loose (18-19ftlbs?) after installing and a month of driving
keep an eye on ur plugs torques...check them periodically otherwise bad things can happen
theres a few threads discussing the issue...mine doesnt have a ton of info but heres
my thread on this
Old 08-23-2018, 02:40 PM
evilchargerfan's Avatar
anyone know the torque spec's for lug nuts?
Old 08-23-2018, 03:16 PM
eulogy's Avatar
the one i cant seem to find, after doing many searches of course, is the torque spec for the antenna. ;D
Old 08-23-2018, 08:22 PM
Frenzal's Avatar
Lug nuts torque is 80 lbf-ft
Old 09-27-2018, 07:21 PM
Going to be needing this info for this weekend, but what are the torque specs for the strut towers when replacing?
Old 09-27-2018, 10:53 PM
GolNat's Avatar
The front strut?
Old 07-29-2019, 04:37 PM
ashbin.singh's Avatar
Thanks great information..
Old 07-30-2019, 05:27 PM
thank you for using the search funtion.
  #32
Old 05-26-2021, 11:22 AM
BukaZ's Avatar
Can someone please post the torque specs for the motor mounts?
  #33
Old 05-26-2021, 11:56 AM
Mister Coffee's Avatar
This help?
  #34
Old 05-26-2021, 10:45 PM
BukaZ's Avatar
Wow! Such a speedy response. Thanks man.
  #35
Old 05-27-2021, 12:02 PM
This is FitFreaks, homes. We don't f. around.
  #36
Old 06-14-2021, 11:22 PM
BukaZ's Avatar
I see that now
  #37
Old 02-16-2023, 01:59 AM
ge808's Avatar
Thanks! Will keep in mind
  #38
Old 08-09-2023, 10:45 PM
spike10000's Avatar
Good help, thanks!
knucklehead
05-10-2019 07:30 PM
sunnyday
07-03-2018 02:11 AM
g fit
11-20-2014 07:24 PM
DrKelso
06-22-2009 08:59 AM
Sid 6.7
02-24-2009 01:16 PM
Quick Reply: Torque Specs
