De36's GE8
#41
Hi De36.Your ride is looking GOOD.You had work hard with it.The CR-Z undershield look GOOD too.It look OEM made for the FIT.Loving those enkei.The best choice for the FIT and for any car out there.Keep the GOOD work bro....
#42
when it comes to aerodynamics, mpg can actually be a tool of efficiency.
A loose one, but a tool none the less.
The hardest part about mpg's is accurate measurement. I sure as hell cannot do better then measuring what I put in each tank stop, and what the ecu displays.
But I do know since Ive been increasing motor efficiency, both power and mpgs have gotten increased!
#45
Indexing Spark Plugs
So I finally had warm weather to install the plugs and check indexing. I installed them with out removing the intake and checked the indexing. A couple were dead on the other two were close so I left them. I did not use indexing washers. I used a mirror and could clearly see the marked lines. Honda has indexed plugs from factory on cars in the past. But I think I just got lucky.
#46
Blox Steering Mount Bushings
Here is a sneak peek of what just arrived FedEx. I will post a DIY in a couple weeks. I am installing steering rack solid mount bushings. Here is where they go and what they.
Blox Aluminum Bushings
Generic pics of a Fits rack:
#48
The bushings are for a S2000 that is why there are 4 bushings, if you notice our racks only have 3 bushings. I don't expect it to be a direct fit, but I know the diameter of the bushings are the same. From the looks of it, the job will take the weekend to figure out a proper install.
#49
I will be honest, Im not willing to drop my rack for the sake of measuring right now, but you will have yours out anyways.........
#50
If you have a digital caliper, measure the Fit stuff pretty well, and I can start having a local CNC shop create solid bushings and also throw in a groove and snap ring if necessary.
#51
Spacing the rack would be an interesting mod. Do you get a lot of bump steer? I thought i'd get more when I widened track but nothing really.
Thanks for following up on the plugs, i'll probably just use a mirror too instead of taking the cowl apart. Either that or just let the shop do it when I get my valves adjusted lol I don't feel like messing with all that DIY.
#52
I never noticed it before, I assume because of body flex and soft rubber bushings can hide bump steer. With the Beatrush bars it's predominate. To the point of annoying. And I've only had the bars installed for a week.
#54
When you install your bushings, take some decent pictures around the mounting. I can probably create a way to raise or space the rack an inch or so.
Keep in mind the swaybar mounting might have to be adjusted.
#55
Blox Solid Steering Rack Bushings
I know I said I would do a DIY but I didn't. Its a big job, but not impossible. It took me longer because I was pioneering new grounds. I could probably do this job in 3-4 hrs if I had to do it again. The steering rack has to be removed in order to press the old bushings out. Removing the rack is actually easy. I used my buddies 20 ton press to get the bushings out. You're not removing the bushings any other way. Can't use heat. I wouldn't do it again, unless the bushing were dry rotted and needed to be replaced.
#58
No. I used the OEM Honda parts catalog to confirm the bushing diameter size. I knew they were going to fit before I even ordered them.
