Sponsored by:
Sponsored by:
De36's GE8
Old 08-12-2014, 01:50 PM
De36's Avatar
Originally Posted by 13fit
use the civic SI K20 factory EGR blockoff plate. Also block off the rear EGR port from exhaust with a 2 bolt wastegate cover from ebay. Many sizes, so measuring is of course key lol
EDIT if you need the part number, it is under water pump section for 2006-2011 civic si. dunno why its in that section, but last 3 digits are J00
I could machine my own, I'm worried about tuning/MIL.
  #102
Old 08-12-2014, 04:08 PM
13fit's Avatar
could always rig up a relay to connect to the wiring, so the ecu sees "something" changing when it tests the EGR circuit.
I remember seeing someones clever way of tricking the EGR circuit, but I believe it was on a different Make of car.
  #103
Old 08-13-2014, 08:42 AM
De36's Avatar
I could trick the ECU with a resistor. But there isn't a HP gain because the EGR isn't open at WOT. The only advantage would a small gain MPG while cruising and "clean up" under the hood.
  #104
Old 08-13-2014, 11:38 AM
13fit's Avatar
blocking exhaust heat from hitting the cylinder head would allow less detonation and more advanced timing.
your coolant system wouldnt be working as hard, and you wouldnt have such a hot intake(besides radiator heat)
I think it would be wortha few ponies
  #105
Old 08-18-2014, 09:13 AM
De36's Avatar
Chassis/ Stitch Welding Chassis
I had a little time on my hands this weekend, so I played around with the welder.
  #106
Old 08-18-2014, 09:42 AM
13fit's Avatar
so now you have filled rear axle bushes, filled front control bushes, and now seam welding.
I bet it feels fairly solid now!
  #107
Old 08-18-2014, 05:04 PM
De36's Avatar
All mods considered; the car feels really good.
At the track a Camaro SS was trying to chase me down for five laps. Finally I got stuck behind a BRZ that wouldn't let me by and the SS caught me.
Afterwards the Camaro SS gentleman came up to me and said: "I had one hell of a time catching you, when we hit the turns you were gone....". It was a nice complement.
  #108
Old 08-18-2014, 08:25 PM
13fit's Avatar
Good to hear about a positive domestic driver. Usually its in their nature to hate on anything under 6 cylinders and non-turbo lol
Just proves how a nice suspension setup is sometimes much more useful then straight up power
  #109
Old 09-02-2014, 03:59 PM
De36's Avatar
Mugen Pedals Heel Toe
I found a Mugen Pedal set on Ebay for $22 USD shipped... Shady... The gap between the OEM brake and accelerator pedal is ~2.75". I installed the Mugen Pedals and it brought the gap to ~1.75". I would still like it closer so a future project is to heat up and bend the brake arm to get closer.
Side by Side Comparison
Gap
  #110
Old 09-03-2014, 12:47 AM
13fit's Avatar
Better left foot braking! Or toe-heeling!
  #111
Old 09-03-2014, 03:47 AM
Myxalplyx's Avatar
I'm particularly interested in you VAFC settings and install. How did you have to tune your vehicle (lean it out or richen it up)? Anything special about wiring that I'd need to know when hooking it up with my Fit? Is it straight forward per their instructions?
  #112
Old 09-03-2014, 01:37 PM
De36's Avatar
All good questions; you should read my DIY:
https://www.fitfreak.net/forums/2nd-...c-1st-gen.html
  #113
Old 09-03-2014, 03:14 PM
De36's Avatar
Thomson Speedway CT
Here's a couple of short crappy videos my gf took on her iPhone.
Front straight pass
From under the bridge
  #114
Old 10-04-2014, 11:39 AM
De36's Avatar
A&J Mirrors
Just Installed.
  #115
Old 10-04-2014, 11:47 AM
De36's Avatar
Spec Clutch Stage 3
Also just came in. I will send the OEM fly wheel to the machine shop to be lighten to ~12 lbs.
  #116
Old 10-04-2014, 06:47 PM
13fit's Avatar
If you dont mind me asking, how much was that clutch assembly shipped to you?
Snap some pictures of the flywheel when its finished, Id like to see a good set of pictures for reference when I send my own one in when spring comes around.
  #117
Old 10-04-2014, 07:30 PM
De36's Avatar
$416 Shipped:
SPEC Clutch Stage 3 Clutch Kit HONDA FIT
I will thoroughly document the flywheel lightening.
  #118
Old 10-04-2014, 09:08 PM
13fit's Avatar
I browsed that website. I saw quite a few items that are known to be separate between GD and GE chassis, yet were listed with same part numbers.
I would verify that clutch is indeed GE fitment. Lots of the JDM aftermarket makes separate part numbers. Perhaps finding bolt and spline differences to make certain.
I am not trying to be negative, just writing what I saw, or at least what I think I am seeing/understanding
  #119
Old 10-04-2014, 11:19 PM
De36's Avatar
TH is terrible and inaccurate with there fitment listings; unless it's a Mustang, WRX or EVO.
https://www.fitfreak.net/forums/1077072-post27.html
  #120
Old 10-05-2014, 12:13 AM
13fit's Avatar
I imagine that confirms it is indeed for the GE, if that post is still accurate for current product offerings.
I would thoroughly enjoy a pucked clutch and light flywheel on this car!
Quick Reply: De36's GE8
