New to forum-about to get 08 Fit Sport auto with 165k
picking this up for my niece who needs to get thru college.
well maintained, one owner fit.
he says it drives fine but does throw a CEL and has misfire in cyl 4 @90k and states he took it dealer and they couldn't find why it threw CEL. coil packs, plugs replaced.
I know I need codes to pinpoint problem and of course owner doesn't remember what codes are.
I asked him to look it up or go back to dealer to pull codes.
still on original O2 sensors.
still drives great.
what problems could be lurking or what should I be wary of??? if it drives fine, CEL is on, it passed inspection...
I do plan to have a diagnostic test done prior to purchase if he doesn't come thru.
actually since I have VIN, I will call dealer to find out myself.
still drives great.
I have an 09 with 155K miles and the only trouble I've had is this:
https://www.fitfreak.net/forums/2nd-...ow-speeds.html
My CEL came on as well with the same code and it turns out I needed a valve adjustment. I'd take the car to the dealer and have them check out the car.
The CAT on these is weak, usually dead by 150K according to a honda tech friend of mine, he says its the ULEV rating that calls the cat bad when it drops below 98% function..
Valve adjust meant every 80 (ish) thousand miles will help with overall run ability.
This thread is for a GD3. OP just posted in the wrong sub-forum, this car is not part of the recall.
Nussjohnathan@gmail.com
11-23-2020 09:03 PM
CTCT
11-26-2012 10:00 PM
