uncontrolled reving on start up
Old 02-27-2017, 05:02 PM
brant914's Avatar
Hi everyone,
not sure where to start
this morning I started my 2009 fit
(drove it to the gas station yesterday afternoon with no problems)
the car started right up, but then revs to red line immediately (while in park)
I touched the throttle to see if it was stuck and the pedal moves freely and doesn't seem to be restricted.
I turned it off immediately
I tried a 2nd time and the exact same thing happened.
I'm not sure but assume its a drive by wire throttle?
any idea where I should start to look, or if this is a common failure?
thanks a ton for the help and ideas
brant
Old 02-27-2017, 05:07 PM
shortdraw's Avatar
Is your throttle on the throttle body under the hood physically stuck?
Old 02-27-2017, 05:10 PM
brant914's Avatar
I will pull the air cleaner tube and inspect as soon as I get home
is it a drive by wire throttle? the pedal felt normal with full return, but if its electronic that probably means nothing
the weird thing is I drove it perfectly normal yesterday afternoon
and drove it 200 miles for the weekend too...
never had this problem previously
Old 02-27-2017, 06:42 PM
shinjari's Avatar
Yes it is a drive by wire throttle system. The throttle body sounds like a good start, but doesnt really explain why it would be open like that when you start the car.
Old 02-28-2017, 01:12 AM
dwtaylorpdx's Avatar
The throttle body typically cycles to WOT and then closed really fast might be a dirty throttle body or the TPS is wacky and it thinks it's closed OR you have a hose off.
Old 02-28-2017, 01:33 AM
ezone's Avatar
Dog food caught in throttle blade?? (rodents chewed through the filter, stored food gets sucked through)
I've seen it more than once.
Check engine light on now? Codes?
Old 02-28-2017, 04:13 PM
Black3sr's Avatar
Maybe some electronic glich. Disconect battery then reconnect. Never know.
You could also check and make surei plug at the pedal is fully engaged. Doubt if loose but check it.
Old 02-28-2017, 04:37 PM
doctor J's Avatar
Disconnect accelerator pedal connector and try to start. If pedal position sensor is bad it will run like a crap but will not rev-up
Old 03-01-2017, 09:20 AM
doctor J's Avatar
Gee, where is the reply from topic starter?? This is the best thing this forum is noted about!
Asking questions, getting bunch of answers and vanishing with no replies.
Hopefully he did not do anything stupid to become statistic of uncontrolled acceleration.
Electronic throttle control, air bags and variable valve timing SUCK big way!!
My next car will be 1973 compact!!
Old 03-01-2017, 05:32 PM
Alco RS-1's Avatar
Originally Posted by doctor J
Gee, where is the reply from topic starter?? This is the best thing this forum is noted about! ......
True, true.
This phenomena seems to prevail elsewhere too, such as in photography forums. Inexperienced topic starters buy expensive cameras, post questions that make no sense and then vanish. Sigh.
noneterry
02-20-2015 10:54 AM
Remould
05-29-2012 11:39 PM
Azizul Zulzaha
12-21-2010 02:58 PM
Pat272
04-07-2007 04:01 PM
phoenity
03-15-2007 11:57 PM
Quick Reply: uncontrolled reving on start up
