Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > 2nd Generation (GE 08-present)
Sign in using an external account
Register Forgot Password?
Register Albums Classifieds FAQ iTrader Members List Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsVendor Directory TSBs
Welcome to Unofficial Honda FIT Forums
2nd Generation (GE 08-present) The New Fit... Generation specific talk and questions here.
Reply
LinkBack Thread Tools Search this Thread Display Modes
  #1 (permalink)
Old 09-09-2008, 10:10 AM
txmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to livetxmatt relies on Rep Points to live
Couple Interesting Fuse Locations (DRL and ABS/VSA)
Was perusing the '09 manual and noticed two things of possible interest...
The interior fuse box location 15 should be the 7.5 amp fuse for the Daytime Running Lights which appears to be DRL only and nothing else.
Also on the inside box, position 11 is a 7.5 amp fuse labelled ABS/VSA* (* = if equipped), position 37 is a 30 amp fuse labelled ABS/VSA* FSR, and in the engine compartment fuse box position 58 is another 30 amp fuse for ABS/VSA* motor.
So it would appear that regardless of whether the car is VSA-equipped or not, the same power circuits and fuse ratings are used. This doesn't necessarily mean that it's all the same components in VSA and non-VSA cars, but I'm still hoping we can determine what pieces are missing from the non-NAV/VSA cars (VSA computer, yaw sensors (possibly in VSA computer module?), steering angle sensor, ...) such that VSA might be able to be added to a non-NAV Fit.
Sponsored Links
  #2 (permalink)
Old 10-04-2008, 11:51 PM
payfitter's Avatar
payfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to livepayfitter relies on Rep Points to live
Points: 275, Level: 5
Points: 275, Level: 5 Points: 275, Level: 5 Points: 275, Level: 5
Level up: 50%, 25 Points needed
Level up: 50% Level up: 50% Level up: 50%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
I am also interested in the possibility of adding VSA to my Fit. I bought the Sport model because the original Honda Fit website listed VSA as standard equipment on the Sport. I didn't find out otherwise till I had already ordered and put a large down payment on mine. If you find out anything about adding VSA I would appreciate you letting me know.
Reply
Tags
09, 30, amp, angle, box, drl, fit, fuse, honda, lights, locations, running, sensor, start, steering, vsa
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Contact Details
Search Engine Optimization by vBSEO 3.5.2
