new pics! tint and drop
Old Nov 3, 2008 | 06:27 PM
strmslvrfit's Avatar
got my tint and drop on tanabe df210's courtesy of jdm_dohc_sir, thank you!
the car is kinda dirty, just the windows are clean hehe. it rained a bit here this morning.
i wanna get rims for the car but i dont know what color i wanna get yet, i know exactly what rim i want just dunno which color what do you guys think? anyone good at photoshopping the rims on the car?? that would probably help
Old Nov 3, 2008 | 06:34 PM
Stormtrooper's Avatar
Idgo with black, as the gunmetals on athat darkish silver is too close, but its just my opinion....
Old Nov 3, 2008 | 06:44 PM
OrangeRevolution's Avatar
Looks great! Hope you don't get any hassle about tint on the front windows. I'd agree that you should get something contrasting in color for the wheels: either silver or black.
Old Nov 3, 2008 | 06:54 PM
ichibahn's Avatar
nice ride!! i just noticed that the rear is lower than the front? do you have somenthing heavy in the trunk or it's just the road angle?
Old Nov 3, 2008 | 08:42 PM
the angle makes it seems much more than it really is. but even on a flat surface the back does look a bit lower than the front. even my older car was like that for some reason.
Old Nov 3, 2008 | 08:50 PM
are you planning to stay 16's?
Old Nov 3, 2008 | 08:53 PM
im thinking of getting 17's actually
Old Nov 3, 2008 | 08:57 PM
1coolride's Avatar
i just noticed that too. nicee color. i'm really starting to like the 09 fits.
Old Nov 3, 2008 | 09:05 PM
Cat's Avatar
Cat
Your car looks great. It is amazing how tint makes it look even better. The drop looks good too.
Cat :x
Old Nov 3, 2008 | 09:40 PM
09BlackPearlMT's Avatar
nice!
I'm thinking about doing the same to mine but the roads here in Minne suck so I'm a little worried about ride quality. Would be interested in hearing about the difference, if any.
re: the rim color, my vote is go with the greater contrast
Old Nov 3, 2008 | 09:47 PM
the ride difference is very noticeable, its stiffer and you feel more bumps, but the handling has been improved
Old Nov 3, 2008 | 09:50 PM
got any sizes in mind? ET? Im looking to get the more mild Tanabe drop, and 17's but fitment has been a concern....
Old Nov 3, 2008 | 10:10 PM
thanks, good to know
what's the difference in drop? am I guessing right that a little more travel will get me a little lighter spring rate? if so then that might be a better fit (sorry) for me.
Old Nov 3, 2008 | 10:12 PM
the rim i want is 17" 7.5" wide 42 offset with 205/45/17 tires, i wanna try and get 195/45/17 tires but i seem to only be able to find 1 manufacturer of that size tire. i heard with this size rim i may get some rubbing issues tho.
Old Nov 3, 2008 | 10:24 PM
ghettoboy247's Avatar
alrite! Anotha GE with Tanabe DF's!!! Don't worry about the rear sagging, give it a couple weeks or drive the car for awhile and the suspension will settle. So about 17's and 205's...
https://www.fitfreak.net/forums/fit-...ots-socal.html
next step, 18's maybe???
Old Nov 3, 2008 | 10:38 PM
hmm
I have "almost" a set of 205/40/17R Bridgestones I may not need, I might run 215/40/17 as it keeps the speedo closest to OE, I noticed that you are in SD, I work there and can get you 3(all I have, you can buy another one from Dicount tires...) they have a lot of tread life left 60 a tire? I think they are like 140-150 new....let me know. if you wanna save some money on rubba.
Old Nov 3, 2008 | 10:40 PM
Tanabe has different height drops and different rates, you can go 1.5 with a rate of only 5% more than OE, or go 1.8 and higher rate, check the site out...I think the Fits ride is on the rough side, so I personally would not go ultra stiff, but to each there own...
Old Nov 3, 2008 | 11:26 PM
IS300na-t's Avatar
What size are your rims? seems like the back can be pushed out another 10-15mm or so
Old Nov 4, 2008 | 12:57 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
another droped Fit. nice job looks great droped.
hey 09BlackPearlMT check out my thread on the RS*R springs
they are 10% stiffer than stock but get you alot lower than stock.
i like them alot so far. comfy and low.
Old Nov 4, 2008 | 01:44 AM
barams's Avatar
you run into any trouble with the po po yet? front tints are cause to get pulled over. don't dd or hold when you drive.
