Fit Extra Dome Lights
Old Dec 16, 2008 | 11:08 PM
Roger's Fit's Avatar
Ok boys and girls, here's another installation of Make the Mod Cheap and Easy, by Roger's Fit
I did the mod on my Suburban. I hate how there is never enough light inside from the dome light. They never wire the dome light into the map lights. So, for $2, I will show you how to do this.
I have moved it to an external webpage:
FitMods.com
Old Dec 16, 2008 | 11:11 PM
dmckean's Avatar
The pictures aren't working.
Old Dec 16, 2008 | 11:24 PM
projekz's Avatar
What are those map lights you speak of? I don't gots none!!!
Old Dec 16, 2008 | 11:26 PM
Virtual's Avatar
Canadian Fits don't have them.
Old Dec 16, 2008 | 11:42 PM
Fixed .
Old Dec 17, 2008 | 12:13 AM
JDM_DOHC_SiR's Avatar
Interesting.....
Old Dec 17, 2008 | 12:24 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
very nice. i like it.
might just have to do it. one of these days.
+rep
Old Dec 17, 2008 | 12:33 AM
713_fit's Avatar
wow smart idea...i do wish all 3 lights on my came on at the sametime..i just might have to do this to mines too
Old Dec 17, 2008 | 12:48 AM
dman's Avatar
Nice mod! +1 rep!
Old Dec 17, 2008 | 12:59 AM
chyperX's Avatar
Thanks again rodger for a great post, just one question can the two front map lights still be turned on seperate with out the centre dome light coming on while driving if passenger needs to do something without effecting driver to much.
+rep 4 u
Old Dec 17, 2008 | 05:46 AM
+rep 4 u
Absolutely
Old Dec 17, 2008 | 06:50 AM
jrlnc's Avatar
Question Does the dimmer effect still work with this mod?
It looks good, just about this.
Old Dec 17, 2008 | 07:29 AM
TKZ12NO1's Avatar
Thanks Roger! I have to see if I can do this with mine but with the big sunroof in the way I might not be able to fish the wire. If I can I"m doing it... my dome light's all the way in the back now and I get no light on the cockpit.
+1 rep for you.
Old Dec 17, 2008 | 05:42 PM
It does still have the dim effect
Old Dec 17, 2008 | 05:47 PM
GUESTO's Avatar
I have a US Spec, 09' Sport model. My map lights look different from yours. There's two big lenses that take up the entire panel, instead of lens, plastic piece & lens. Is yours US spec too?
Old Dec 17, 2008 | 06:05 PM
It is US spec, and I have navigation. The center is the microphone. It will still work, you just have to connect to the right terminals.
Old Dec 18, 2008 | 08:57 PM
S0L_GT's Avatar
Great post! I was hoping someone would out line this... between this and the upgraded console, I will be even happier with my FIT after this weekend.
Old Dec 18, 2008 | 10:37 PM
GUESTO's Avatar
Man, that's cool. I'll definitely will be doing this. The center dome light is too dim.
Also, I was wondering. The microphone part of your map lights, from DIYHonda.com Video Podcasts there was a show about swapping out these pieces with homelink. Can anyone confirm if it'll fit?
Old Dec 28, 2008 | 07:44 PM
S0L_GT's Avatar
Thanks again for the guide on the light mod. Everything was straightforward and the parts were easy to find at radio shack. The only trouble I had was getting the dome light to hold onto solder, no matter how much i sanded or cleaned it, even tried two different types of solder. Aside from that, everything went together flawlessly. Lights work as promised, dimming and all.
Old Dec 29, 2008 | 08:18 AM
BakedCookies's Avatar
looks good, but I would have definitely recommended some heat shrink over the connection points to the diodes.
