Mods to date, Interior Complete!
Old Dec 29, 2008 | 02:27 PM
SRLNCLT's Avatar
Originally Posted by BakedCookies
Yeah, but you have to tape up the HVAC controls and all the surrounding plastic, then there is a pry hole hidden inside the top glove box, but it takes a lot of effort to make the radio start to pop out.
It's not a cover, its the entire radio and the top vents that all come out as one piece, the only good thing is there is enough slack in the harness that you don't have to unplug anything except the hazard button to install it.
Yep. I looked into it quite a bit, actually b4 I bought the hazard button.
Old Dec 29, 2008 | 04:36 PM
JDM_DOHC_SiR's Avatar
Exclamation
Thanks, its a b!tch to install, have fun
I have some tips though in my original thread on its installation.
Link to the DIY..??
Old Dec 29, 2008 | 05:08 PM
FitStir's Avatar
Thumbs up
Originally Posted by JDM_DOHC_SiR
Link to the DIY..??
It's not a full DIY, but some definitely has some very usefull tips.... this is the link to the original thread ---> https://www.fitfreak.net/forums/2nd-...first-mod.html
I'm guessing its the following post.
Also btw, to remove the headunit you only have to do two steps, unlike what college hills shows for installing the USB hookup.
1. Remove panel directly below the fresh air/recirc lever, then look up in hole, you will see a circle cutout in the assembly and a screw in there, remove with philips screwdriver.
2. Open top glove box and using a thin flatblade screwdriver (I taped mine with painters tape and the area i was working in) insert it in the slot that's located in the upper right hand side of the head unit assembly. I had to push it in fairly far and then pry up and outward. Eventually a few clips will pop free where you can get your hand behind it and remove the headunit.
You can then unhook the connector to the hazard switch and remove the 2 philips screws securing it, you do not need to unhook any of the headunit wiring. There is plenty of room to work. Install new switch and test, reverse removal steps and you're done.
*Note: the face of the top HVAC vents will come out with the headunit.
Old Dec 29, 2008 | 05:21 PM
Thanks!!.. . ..
Old Dec 29, 2008 | 08:43 PM
BakedCookies's Avatar
yeah FitStir that's it, sorry for the delay on the reply.
Old Dec 29, 2008 | 11:12 PM
SRLNCLT's Avatar
^^What were ya doing taking so long? Baking cookies?
evilchargerfan
Jan 25, 2026 08:21 AM
Fitderp
Oct 10, 2013 12:25 PM
Scaldy
Jun 15, 2011 01:02 AM
555sexydrive
Jan 12, 2010 04:50 AM
