Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > 2nd Generation (GE 08-present)
2nd Generation (GE 08-present) The New Fit... Generation specific talk and questions here.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 06-19-2009, 06:20 PM
ASBJUNK is an unknown quantity at this point
My 09 Sport AT Fit is making strange crunching noises.
When I turn the key to the second position right before the ignition when hondas turn the fuel pump on and you can hear it pumping, I am hearing a second noise possibly comming from the pump.
Sounds like a crunching or maybe bubbles or teeth of a motor missing a sprockets gears or something.
I also noticed the car starts after one or two turns of the starter when cold, when hot it starts immediately. And the noise seems to be more persistant when the car is cold.
It isn't the starter making the noise cause I am not turning the key past the second point.
Has anyone else noticed this sound and identified it, or just noticed it? In order to hear it you must have all accessories off that make noise, fan and ac and such.
-A
Sponsored Links
  #2 (permalink)
Old 06-19-2009, 06:59 PM
qbmurderer13's Avatar
qbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to live
I have the same problem. It definately sounds like its something in the fuel pump. Just thought it was normal. Rather deal with it than have the dealership tear apart my car like savages replacing something that isnt broken.
__________________
My Detail Threads
  #3 (permalink)
Old 06-19-2009, 07:39 PM
Quote:
So you consider it a problem.
Do you feel that your fit doesn't start right up as a new car should..?
I feel it might be related.
Can anyone else listen for this and report back to this thread please.
  #4 (permalink)
Old 06-19-2009, 07:44 PM
reako's Avatar
reako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to livereako relies on Rep Points to live
I don't hear anything out of the ordinary on mine.
__________________
2009 SSM Fit Sport AT w/Navi
  #5 (permalink)
Old 06-19-2009, 09:23 PM
It shouldnt be making that noise regardless if its a "problem" or not. Which in my case it doesnt effect the car. It turns on fine.
__________________
My Detail Threads
  #6 (permalink)
Old 06-20-2009, 02:07 AM
sl1pg8r's Avatar
sl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to livesl1pg8r relies on Rep Points to live
i hear it in my fit as well... when turning the key to second position a crunching noise... i'll call my dealership about it and report back. if any else has any more info please lemme know! i got a mt 09 sport fyi.
__________________
____________________________
call me slip
  #7 (permalink)
Old 06-21-2009, 02:51 PM
Quote:
Mine is AT, so we know it's less likely to be a tranm issue.
I think it is teeth in the fuel pump sprocket getting missed, and crunching. Just my thought.
  #8 (permalink)
Old 06-22-2009, 01:55 AM
dsdandaman's Avatar
dsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to livedsdandaman relies on Rep Points to live
i got an AT 09 fit. it does the same thing too. only when it's cold.
  #9 (permalink)
Old 07-05-2009, 08:21 PM
Anyone with this issue having cold start issues meaning, the cam shaft has to turn three four times before engine kicks on?
Like diidiidiivroom, or diidiidiidiivroom?
  #10 (permalink)
Old 09-06-2009, 01:56 PM
daveymcgav is an unknown quantity at this point
Yeah, I've noticed that my Fit has this same noise and it's now taking longer to start up than it did when new (I'm at 6500 miles).
Has anyone gotten this fixed by the dealer?
  #11 (permalink)
Old 09-06-2009, 02:18 PM
badself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to livebadself relies on Rep Points to live
I think the fuel pump guess might be right.
For sure, the Fit as a whole is relatively reliable, but trouble-free, I couldn't say that about mine, Japanese build or not. My Mazda CX-9 was assembled in Hiroshima, but the same applies to it.
I'm starting to think that the gap between Japanese and "anything else" build isn't as large as I once believed, at least not for my two vehicles. Aside from Chrysler and Maseratti (where q/c is non-existent), most manufacturers have had to get better or perish, not just with build, but with the quality of their sourced parts.
  #12 (permalink)
Old 09-06-2009, 04:46 PM
chubbykai's Avatar
chubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to livechubbykai relies on Rep Points to live
has anyone experience a CLICK sound when reversing and then right wen you put it into drive and start gassing it it goes CRLICK? lol
  #13 (permalink)
Old 09-06-2009, 11:22 PM
Shockwave199's Avatar
Shockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to liveShockwave199 relies on Rep Points to live
Yes- me too. Takes a second or so longer to fire up when cold. Warm it turns right over. I'm a little over 500 miles on the engine now. I have not noticed the crunching noise though. I'll have a listen later when the car cools down again.
Dan
__________________
<img src=http://img.photobucket.com/albums/v206/shockwave199/Fit_3-1.jpg border=0 alt= />
'09 Sport, A-T, mesh guard installed
  #14 (permalink)
Old 09-07-2009, 01:10 AM
awptickes's Avatar
awptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to live
My fit took longer to start when it was cold, and I realized it was the way I was parking. I started letting it idle a bit (maybe three seconds) to stabilize RPMs at 750, and it starts up in no time at all. I have to do the same thing with my Civic.
I would go in and ask about the noise. See if you can get them to listen and at least tell you what it might be.
The fuel pump is relatively simple on the GE8. Completely accessible from outside the car.
Actually:
Try having someone start it while you slide up under the car around the driver's seat area. You should instantly know where the fuel pump is, and if the noise is coming from there.
  #15 (permalink)
Old 09-21-2009, 10:48 PM
I wanted to post back here because I've been following a few peoples advice here to hang in ignition position [2nd position with key before starting] for a couple of seconds and then start the engine. This has been working and starting the car has gotten noticeably better. Out here in the burbs of NY, it's still not freezing yet but it was down in the 40's last night. Following this proceedure, the car turned right over. Even the first start of day when it's warm out, it does the trick. My Fit has never really been troublesome to start- just took a wee bit longer to turn over than I would expect in a new car, when starting cold. This proceedure has eliminated any hesitation upon startup. The only time I don't need to do it is if the car is warm already- such as store hopping, errands, and such.
So to the few who recommened it- thank you!
And to those who've experienced this, give it a shot. It does work well, IME.
Dan
__________________
  #16 (permalink)
Old 09-21-2009, 11:17 PM
Someone that spends her life on FitFreak.net
TaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to liveTaffetaWhite relies on Rep Points to live
Quote:
That could be your brakes.
Why do my brakes make a single “click” noise when I back out of a parking place and once again when I drive forward?
A clearance between the brake caliper brackets and the ends of the brake pads allows for heat expansion and avoids corrosion between the caliper bracket and the brake pads. That clearance can cause the pads to hit the caliper brackets when you first apply the brakes in a new directions of travel. When you back up and apply the brakes and then drive forward and apply the brakes, the single “click” noise you hear is a normal characteristic of the brake system.
Frequently Asked Questions - the Official Honda Web Site
__________________
FitFreak Fossilized Fuddy-Duddy
  #17 (permalink)
Old 09-21-2009, 11:37 PM
mike2100's Avatar
mike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to live
Gee, if everyone hears the noise then it's probably not a problem.
And 3-4 turns before starting is NOT a problem. Trying keeping the key in the ON position a few seconds before you crank it to allow the fuel pump to prime and pressurize the system.
__________________
09 TW Sport MT
08 SSM Sport AT
  #18 (permalink)
Old 09-22-2009, 12:36 AM
chubbykai's Avatar
i saw that but it doesnt really make sense to me. w/e it doesnt affect the car lol
  #19 (permalink)
Old 09-22-2009, 12:51 AM
It's like pants.
Put on pants that are comfortable. Suck in your stomach so the pants are loose. If you pulled the pants from the front, the back of the pants would hit YOUR back (and in the case of brakes, stay there). Pull the back of your pants and the front hits your front.
Push out your stomach, and that's like the expansion of the brake pads and there is no loose give when pulling on the front or back of the pants.
Luckily, massive holiday meals have no effect on brake pads and we do not have to unbutton the top button of brake caliper pants.
That will be today's bad analogy.
__________________
  #20 (permalink)
Old 09-22-2009, 01:24 AM
chubbykai's Avatar
LOL thats actually not a bad analogy. you should teach kids as a side job haha
+rep for the effort lmao
Reply
Tags
braking, civic, crunching, fit, honda, key, maing, making, noise, noises, strange, turn, turning
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Base or Sport? Manual or Sport Auto? piyoimut Fit Freak Newbie / FAQs 16 06-17-2009 06:25 AM
Sport vs LX icarl General Fit Talk 3 02-10-2008 10:00 PM
2004 (2003-model) Honda Jazz SE Sport terryb Fit Photos & Videos 2 07-20-2007 06:28 PM
DX, LX, or Sport??? phylae Other Car Related Discussions 22 05-21-2007 10:09 AM
So your looking for a Manual Fit Sport are you? pingpop Ohio Community 0 03-03-2007 11:54 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
