Rear disc brake conversion
Old 09-22-2009, 07:22 PM
FITMugen's Avatar
Has anyone done Honda FIT / GE8 rear disc brake conversion before?
Old 09-22-2009, 10:56 PM
Committobefit08's Avatar
It has been discussed before. Search is your friend.
https://www.fitfreak.net/forums/2nd-...s-09-fits.html
Old 09-23-2009, 05:06 AM
thefit09's Avatar
Yeah, but that thread isn't. T1R doesn't make em for the GE's. You'd have to do some searching to find something you could actually bolt on.
Old 09-23-2009, 07:03 AM
Thats my point. There is nothing currently on the market.
Old 09-23-2009, 07:40 AM
thefit09's Avatar
Pretty sure your point was to emphasize the handiness of search.
Old 09-23-2009, 12:55 PM
nealy's Avatar
Someone should try using 02 - 03 EP3 rear disks, as soon as I get ahold of some I'll try, if I don't get ahold of a 5 lug disk conversion first.
Old 09-23-2009, 01:04 PM
He would have saw if he had searched that there was nothing currently on the market.
The link was an example of that.
If I wanted to emphasize the handiness of the search...I would have linked the search results you think?
Old 09-23-2009, 01:14 PM
Another possibility would be like Neebs mentioned in the link I attached above... and try getting your hands on a salvaged one off the EDM or JDM Jazz since they come stock with rear disc.
Old 10-25-2009, 01:06 PM
FitStir's Avatar
Any update?
Has anyone done a rear disc conversion on a USDM GE yet?
Old 10-26-2009, 06:15 PM
bmxman's Avatar
hmmm..I wonder how many of you are actually pushing your Fit so hard that you really need rear disks....today's drums are a lot better than most people think.
Old 10-26-2009, 07:04 PM
Virtual's Avatar
They also don't require as much maintenance and are less expensive to service.
Old 10-26-2009, 07:40 PM
Hondafrk's Avatar
Yeah I too don't really understand why people think the GE needs rear discs.... Its not fast, its not heavy, it doesn't need rear discs.
Old 10-26-2009, 08:01 PM
Jodele's Avatar
but still not that good...I have not had a self adjusting mechanism work past the first week of use. And with drum brakes, you have a very long pedal travel. With discs you get much better feel. definately worth the trouble to convert...I love them on my GD3.
Old 10-26-2009, 08:22 PM
mike2100's Avatar
Considering the front brakes do 75% or more of the braking a rear disc conversion is a waste of money for anyone not seriously racing their car on a track.
Old 10-26-2009, 11:24 PM
MugenAP2's Avatar
It looks good though!
Old 10-27-2009, 02:00 PM
biscuitninja's Avatar
For me, i just want to have a lighter car... those drums are HEAVY and add considerable weight. The biggest bang for your buck is dropping unsprung weight. So ditching the springs and going coil over as well as lighter wheels and ligher breaks yeild big returns on chassis and unsprung weight.
Plus when I actually do track the car, any little bit helps. But ideally having bigger front discs is the way to go, although you must have balanced breaking if the front are too powerful, the rear need to be just as poweful.
just my thoughts. I'm just suprised that nobody makes anything for the fit... the civic, well there all all sorts of things.
Old 10-27-2009, 03:05 PM
mike2100's Avatar
Wow that's interesting, because on the CRX the drum brakes were lighter than the Si's disc setup.
Old 10-27-2009, 06:58 PM
specboy's Avatar
I believe Rear Discs cool quicker than a rear drum setup so anyone who wants to AutoX or hit a road course hard would want discs all the way around.
~SB
Old 10-27-2009, 11:05 PM
Wopasaurus's Avatar
I drive like a regular Joe...I just think discs look waaaaaay nicer.
Old 10-28-2009, 01:24 AM
mtunofun's Avatar
drums are more economical and good enough blah blah, but it's still inferior to discs. Leaving the carwash approaching a red light, I knew the brakes were wet because I know how long it takes my car to stop from 40mph in dry weather. When wet, it takes twice as long. Also, you can't check the shoe thickness like you can with disc pad thickness...you have to pull the wheel off yourself or pay someone to inpspect. DRUMS ARE POS.
Quick Reply: Rear disc brake conversion
