Quote:
I noticed another member put Mugen suspension from a GD onto the GE. Right now I'm lowered on Eibach Pro-Kits. However I'm really not satisfied with the way the car bounces repeatedly when going over bumps and I get a lot of body roll still. When summer comes around I'll definitely be getting wider tires. In the mean time I would like to upgrade the shocks but nothing is available. I don't want to drop more money on the T1R B2s yet. Just I like the ride height of the pro-kits and adjustability is not a concern for me. Just want stiffer shocks to go with the springs.
Eibach Pro-Kits like many other progressive lowering springs are softer than stock at the top and harder at the bottom of the spring.
On perfect roads progressive lowering springs are great, but on slightly uneven road surfaces you will feel more sway, bounce and roll at slower speeds because the car is driving on the softer part of the spring.
The problem is, it's hard to find linear lowering springs for the GE that's why many people use the stock GD springs on the front.
These springs are the same diameter at the top and bottom, a bit shorter and a little stiffer.
Other cheaper options are to turn over the progressive front springs as they are the same diameter top and bottom or fit a quality spring stiffener at the top of the spring.
On another forum I read people actually wrap hose pipe around the top coils and it helps a bit.
