Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > 2nd Generation (GE 08-present)
2nd Generation (GE 08-present) The New Fit... Generation specific talk and questions here.
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 11-03-2009, 07:30 PM
Chad T's Avatar
Chad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to live
Also you've got a lot a variables that can cause you to see steam at the car wash. Outside temp, water temp etc. Ever see steam when you breathe in cold weather?
__________________
2009 MT Base Fit
1986 Shelby GLHS #088
  #22 (permalink)
Old 11-03-2009, 07:46 PM
BayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to live
It sounds normal if you put cold water on brake pads.
Also, do not go through ANY car wash. It is always better to wash your car at home. Those brushes in the car wash only slap your vehicle with crud leaving you with swirls, scratches etc.
__________________
Alex
In my Garage: Fit/3 Series/BoxsterS/NSX/Prius
  #23 (permalink)
Old 11-07-2009, 07:48 PM
DZeckhausen's Avatar
DZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to liveDZeckhausen relies on Rep Points to live
The reason they are so hot is because they are tiny. At 262x21mm and only 12 pounds each, it doesn't take much to get these rotors very hot. After a stop, you're temporarily storing all the kinetic energy of the vehicle as thermal energy in some very small "storage" containers. (the rotors)
Now if you could install some Dodge Ram SRT-10 rotors, then you could probably touch them with your hands after a 5 minute drive! The SRT-10 rotors are 380x36mm and 40 pounds each. Of course, your acceleration would be even worse than it is and the ride and handling would be affected.
__________________
Dave Zeckhausen
2009 Fit Sport w/NAV
  #24 (permalink)
Old 11-07-2009, 10:29 PM
binaryh4x's Avatar
binaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond reputebinaryh4x has a reputation beyond repute
Quote:
Only when my lung is dragging.
__________________
I'm like the angle opposite of the hypotenuse, always right.
  #25 (permalink)
Old 11-09-2009, 12:11 PM
JFit317's Avatar
JFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to liveJFit317 relies on Rep Points to live
my Fit had the problem too, but...I was also mobbing the hell outta it.
__________________
-Indianapolis Straight Edge-
  #26 (permalink)
Old 11-09-2009, 12:15 PM
I did an experiment yesterday, since the Fit was dirty and I ran out of time to wash it, since we had guests coming over for a BBQ. So I took it to the local (good) carwash. When the spray hit the front wheels, steam came billowing out.
I hereby declare this event - Normal!
__________________
Dave Zeckhausen
Reply
Tags
07, 30k, brake, brakes, civic, cold, drive, fit, honda, hot, miles, normal, rotora, rotors, sale, water
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
rotora slotted rotors F'it_ImFromTx Fit Suspension & Brake Modifications 41 07-19-2009 10:23 AM
Are Fit <-> Jazz brake rotors interchangeable? TheBlack Fit Suspension & Brake Modifications 0 06-29-2009 06:11 PM
FS: Wilwood 'Q' Compound Race Brake Pads Sid 6.7 General For Sale Section 1 05-28-2009 02:08 AM
Light Weight Brake Rotors lanakano Fit Suspension & Brake Modifications 1 12-06-2006 07:22 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
