led key ring is killing my battery
Old Mar 2, 2010 | 07:40 PM
wireman420's Avatar
so i went on vacay skiing only for three days and my battery is dead so i gave it a jump and it was good then i hit a pothole and got a flat there was no patching to done so i ordered a tire from tire rack the next day i tried to start dead again so i jumped again let it run for 20 mins next day i try to start dead do u guys think i should remove led key ring or change wiring so it comes on with dome lt when i open door or is that even possible
Old Mar 2, 2010 | 07:49 PM
Selden's Avatar
Someone else reported a similar problem several months ago. Remove the keyring light, or wire it to overhead light circuit.
Old Mar 2, 2010 | 08:24 PM
smartpolak88's Avatar
I had the same problem with the key ring, tried to start the car in the morning after not driving it for 1-3 days and battery was dead. Happened a few times, then I finally decided to get rid of the key ring and never had any battery problems since.
Old Mar 2, 2010 | 08:52 PM
Roger's Fit's Avatar
Can you say that with one breath?
Old Mar 2, 2010 | 09:07 PM
vinn's Avatar
theres a reason why it didnt come stock, i had a similar incident....im not gonna say what happened though
Old Mar 2, 2010 | 09:38 PM
Virtual's Avatar
I have to add that running 20 minutes isn't enough to fully charge a dead battery.
Old Mar 3, 2010 | 12:32 AM
Fitting's Avatar
I've the led keyring and wired it to come on with the dome light. No problem at all.
Old Mar 3, 2010 | 05:19 AM
Black3sr's Avatar
I doubt if a keyring LED would kill a battery in 3 days. Sounds like some other electrical problem.
I wired my keyring like KoolKev suggested to work with dome and no problems.
Old Mar 4, 2010 | 11:40 AM
wireman420's Avatar
thanks for the feedback guys
Old Mar 5, 2010 | 12:11 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
i agree with you on this in can't be the key ring.
i had my car sit 3 days at a time also went on vaca
for a week and it still started no problem.
funny thing is my key ring is on all the time. it's either
blue or flashing red.
so you either have another problem somewhere else or just
a bad battery.
the bad battery has happened to a few people on here
already. even to me.
but the best way to go about it is process of elimination.
Old Mar 5, 2010 | 09:00 PM
GE swag's Avatar
same prob here about the 3 day thing. i installed it, then left for the weekend...came back on monday, and the darn thing killed my battery.
i didnt think that it was the cause of the problem until other ppl started reporting the same prob.
Old Mar 7, 2010 | 06:10 AM
Lyon[Nightroad]'s Avatar
I have upward of 25 individual led lights 14 superflux 4-chip LEDs and 8 LED strips. I have left everything on for 8 hours straight and not had the battery go dead. Check your wiring.
Old Mar 7, 2010 | 09:08 AM
GE swag's Avatar
Dude. I followed those directions from that foo koolkev
Old Mar 7, 2010 | 12:31 PM
Black3sr's Avatar
Funny then why some of us have no problem using Kool Kev's instructions.
Old Mar 9, 2010 | 04:40 AM
Black3sr's Avatar
Originally Posted by GE swag
Maybe cuz ur a gayass
What has that to do with you not being able to follow simple instructions to wire a keyring light?
I am just saying some of us have had no problem using these instructions.
Old Mar 9, 2010 | 03:24 PM
Red 05's Avatar
I don't really see a need to have that installed, so I don't bother with that.
Though I have to admit that was the first time I've seen that kind of language here... >.<
Old Mar 9, 2010 | 04:01 PM
gimme's Avatar
Master FitFreaker
how about we stay away from name calling and stay on topic.
Old Mar 9, 2010 | 10:13 PM
Tork's Avatar
exactly, give the guy a little vacation for doing that.
back on topic
I think you wire it to your dome you will be ok.
People who may be getting away with it may do more highway driving.
My suspicion is driving city or shorter distances does not keep the battery fully charged.
Old Mar 9, 2010 | 10:22 PM
Daemione's Avatar
With or without a tiny LED, the combination of a small/weak stock battery, short trips only, and letting the car sit for a day or two will kill the battery.
I'm running a tiny Deka battery, and I've got my LED ring wired to be on 24/7. As long as I drive the car enough (read: my 2 mile commute, and a trip of at least 10 miles once a week) it's been fine - even all winter. The amount of power one of those LED's use is laughable.
Old Mar 10, 2010 | 07:55 PM
aenokea's Avatar
Ive had one of these installed on my car for over a year now and have not had any problems with a draining battery. The Fit is my daily driver but there are times when I have to drive my other car and the Fit sits during the week. Yet its never failed to start when I needed to drive it. I have mine wired to be on 24 hrs.
