Sponsored by:
Sponsored by:
abs light and wheel sensor replacement
Old 04-19-2012, 02:19 PM
Santiad's Avatar
So I've replaced both wheel speed sensors in my fit a few months after having the wheel bearings replaced.
I went about it replacing one at a time. Right side replaced at honda: no dice. Light still one because of the left side (according to service advisor)
I replaced the left one myself this morning. Light still won't go off. (Disconnected battery)
I will say the mounting tab of the sensor isn't perfectly flush to the knuckle, enough room to fit a screwdriver and pry it out. I found it hard to push it past that point without a soft mallet (which I didn't use).
Any advice on why the light might still be on?
Old 04-19-2012, 05:13 PM
teamkitty's Avatar
I still say that one of your bearings was pressed in backwards. Although they fit both ways, the pickup for the sensor is only on one half. Happened to me.
Old 04-19-2012, 05:40 PM
Santiad's Avatar
No way to confirm this without taking out the knuckle?
Old 04-20-2012, 01:30 AM
teamkitty's Avatar
I personally don't know for sure, but from what I've read, the seals on each end of the bearing are different colors: brown goes inward / black goes outwards. Hopefully that helps at least figure out which side (if not both) needs attention. Good luck.
Kristinb737
04-07-2024 10:35 PM
jdDC
12-30-2015 02:52 PM
andyd
02-23-2012 11:55 AM
Santiad
10-17-2011 02:55 PM
RandomKoko
01-27-2009 10:49 PM
Quick Reply: abs light and wheel sensor replacement
