Sponsored by:
Sponsored by:
TPMS & OBDII code?
Old 09-09-2012, 01:48 PM
smetzger's Avatar
TPMS & OBDII code?
Hi,
So, TPMS light is on. Took it to Advance Auto and they scanned it but no codes showed up.
If the TPMS light is on should it throw a code?
I am not familiar with scanning for OBDII codes.
Is it possible that the tech scanned it wrong? Perhaps, one has to select a specific module to scan for?
Thanks,
Scott
Old 09-09-2012, 02:58 PM
is it the TPMS light on or is it the TPMS indicator light? if its the indicator, refill your tires...could have a small leak. if its TPMS light then either a) your sensors went bad b) sensor cracked c) system needs to be reset
did you change your wheels? if you havent done anything at all, dealer should be able to fix this issue for free if still under warranty. i just had my system reset and 1 sensor replaced after i had swapped my stock wheels for aftermarket.
Old 09-09-2012, 03:02 PM
smetzger's Avatar
It is the TPMS light.
I have not changed the wheels.
The car is out of warranty.
So...how do I determine if it is
b) sensor cracked
Old 09-09-2012, 03:06 PM
you would have to take it to the dealer and/or a TPMS certified place. In my area Goodyear and Firestone can check this. But Dealer will probably warranty the work. But this is not cheap at the dealer. call around and see.
Could just need to be reset. But if its a bad sensor then they will have to dismount tire and replace sensor then drive car with system connected to reset the sensors. i just did this yesterday. but i got them to do it for free
Old 09-09-2012, 05:34 PM
SieGunso's Avatar
my tpms light came on after about 20 miles when i picked up the car from dealer. tire was over filled and need a reset.
maybe check if it's above the recommended pressure.
Old 09-09-2012, 07:16 PM
smetzger's Avatar
I did some research. Looks like I need at least the ATEQ VT30
ATEQ TPMS VT30
and I may also need the ATEQ Quickset
ATEQ TPMS QuickSet
But the VT30 is pricey... $250 - $300 and the Quickset isn't pocket change at $150.
Does anyone know of a more affordable way for the home mechanic to diagnose the TPMS Malfunction indicator themselves?
Thanks,
Scott
Old 09-09-2012, 07:19 PM
smetzger's Avatar
Did your TPMS Malfunction light come on (actual TPMS letters)?
Or was it what is referred to as the low pressure indicator (symbol of tire with a nail in it)?
Old 09-09-2012, 07:20 PM
malraux's Avatar
Sometimes autozone and the like will rent tools. Have you done the obvious but futile thing of checking all four tire pressures? It won't help, but it's easy to do.
Old 09-09-2012, 07:26 PM
smetzger's Avatar
I have checked pressures.
I usually run about 5 over recommended pressure for performance reasons.
I did lower all pressures to the recommended pressure, but that didn't change it.
Besides, I wouldn't think the TPMS malfunction light would come on for incorrect pressures.
Old 09-09-2012, 08:58 PM
malraux's Avatar
I wouldn't think so either, and the FSM doesn't say if high pressure can light up the error indicator. It was more of a thing to do cuz its easy and cheap.
Unfortunately, the FSM also says that you cannot clear the error codes from the system by unplugging the battery; only the honda data interface can clear them.
Old 09-10-2012, 10:30 AM
yah, you can't clear tpms with obd2 scanners that i know of.
Old 09-10-2012, 11:25 AM
NIGHTHAWKSI's Avatar
TPMS syste and the OBD system are not linked together at all.
the TPMS light means there is a malfunction with the system. - brolen sensor, no sensors, etc.
the light that looks like a tire with an explaimation point in it means your pressure(s) are wrong. - due to overinfaltion or underinflation.
disconnecting the battery for a while will reset the TPMS light...about 30 minutes. but unless you fix the problem, it will come back within 20ish miles of driving.
Old 09-10-2012, 02:16 PM
mahout's Avatar
i don';t have time to check the manual but I believe the sensor malfunction code will show on a OBD ii checker, which you can buy for ca $50 at many aftermarket parts stores like AutoZone, Discount Auto Parts etc. Some will prerform the check for free.
so check your tire pressures are above 30 psig and then check ii if the ight doesn't go out. Sometimes it may take a few miles iof driving before the light goes out..
Old 09-10-2012, 11:47 PM
wetphoto's Avatar
Take it to Discount Tire. They reset mine for free.
Old 09-10-2012, 11:48 PM
wetphoto's Avatar
Mine went TPMS first, then the tire showed up and TPMS went away
corygibson
05-23-2013 09:15 PM
CptanPanic
07-28-2010 04:10 PM
Bustov
02-25-2009 01:40 PM
Pursang
03-31-2008 06:41 PM
percy
12-10-2007 03:37 PM
Quick Reply: TPMS & OBDII code?
