07fit916 GE Progress Thread
Eventually I want to Put RPF-01's on my new Fit, thanks for your in depth post,
I'd be interested in your current shift knob if you could send it to TX.
Car looks great man, I also plan on autocrossing mine as well, and tips on gotta have upgrades? Also what class do you run in?
I run in STF class in autox. As for upgrades you really don't need anything. I'd start with tires if you really want to buy something though. A tip that I ignored, but know the value of, is that seat time will be your best upgrade.
side work. photo booths for weddings and birthday parties etc.. they had me outside which i normally dont like but i was able to use the trunk as a chair for the night. nobody had shown up to take pictures yet so i snapped a couple pics.
#32
Can you tell mw about the koni setup you have and the rpf1s you have. It is between rpf1s, kosei k1s and 949 6uls. I am starting to look at suspension upgrades but have not been able to pinpoint what coilover setup would be best. I like the height you are set at with the wheels. Any info would be great. Did I read that you put a different driver seat in or did you say seat time behind the wheel driving?
#33
Redshift Koni/GC review
I use the rpf1's for daily driving and I use the 6UL's for autox. The 6UL's with a 225/45/15 tire are awesome except when it comes to courses with straights that are a bit too long. I've been on the rev limiter a lot with them in a few different courses. I believe 2nd gear tops out at about 52mph which is just the tiniest bit too low.
I've been wanting to put a new drivers seat in ever since I saw DoYouFit?'s recaros. But that will have to wait. As for seat time behind the wheel, thats the best thing you can do to improve your times. You could just autox with the car in stock form. That would probably help you out in deciding which direction you want to go as far as modifications.
#35
Cool job.
#36
Alright so question for the OP, I am wanting to know your thoughts on how the fit would handle if I chose this path to begin with. I am learning the limits of the stock fit and wonder how it would feel if I added the rsb, and 2 or 3 o the underbody braces and leave the stock struts and springs.
#37
#39
I'm not totally sure but the s.drives run pretty wide. I'll try to snap some pics later. If they do stick out its gotta be like millimeters. And since I'm running negative camber it's really only at the bottom.
