Tires Really Do Affect Fuel Economy
Old 08-01-2014, 12:59 PM
Keep in mind the general rule of thumb that LLR (low rolling resistant) tires = better MPG BUUT worst-er traction. Traction is not just lateral Gs, but also braking ability. No tire can defy the laws of physics. What is worth more to you? That little contact patch on your tires is the only link between you (car) and the road. I firmly believe a great tire for one person may not be so great for another. Just have to figure out your priorities.
Old 08-01-2014, 01:19 PM
Steve244's Avatar
The Michelin Energies are a good compromise between traction/handling and LRR. They get better MPG than the stock Dunlops and better stopping/handling. The Dunlops were toast at 30K, I'm at 45K on the Michelins with plenty of tread left.
I've only activated the ABS on ice with the Michelins. The Dunlops were always setting it off on wet pavement even when they were fresh.
You can eat your cake and have it too:
Old 08-01-2014, 10:30 PM
13fit's Avatar
If you are worried about traction, just find a super economy tire in a wider size. the extra width will make up for the traction difference.
Plus wider tires look better. the factories look like a full set of donuts
Old 08-02-2014, 11:31 AM
mahout's Avatar
Originally Posted by larrymcewin
Blew through my stock 15 inch tires at 30k miles on my '12 base.
When I went to the tire store to replace them, the guy at America's/Discount Tires suggested Arizonians (Cooper) and upped the size to 185/65-R15s (from the stock 175/65-R15s). I noticed a small drop in fuel economy (2-3 MPG).
I wore out those tires after 45k, so I bought some Goodyears (185/65-R15s also) that were on sale. Turns out, they are the "ComforTread" tires. While the car was incredibly quiet, and smooth over bumps, it destroyed my fuel economy.
I went from 35 MPG on the freeway to 29 MPG instantly. I couldn't get the car to go above 30 MPG no matter how many hills I coasted down in neutral.
Swapped 'em for some low rolling resistance tires (Michelin Energy Savers) and went back to the stock 175/65-R15 size. I'm pretty much back to the MPGs I was seeing with the stock tires. The car is bumpier and noisier again, though. But that's the trade off for good gas mileage, I suppose.
Anyway, wanted to pass along as a head's up. The tires really do affect MPG on this car, more than any other I've ever owned.
Lets repeat again for the unwary:
1. larger diameter tires will hurt mpg unless you drive all the time on flat level roads.
2. heavier weight tires will decrease mpg.
Before buying new tires do your research. Consult the data on tirerack.com for diameter and weight data on tires and choose what you want. If you want better peformance by increasing tire width reduce tire diameter to at least make up some of the loss fromheavier tires. And you can reduce diameter by 1/4" without significantly affecting speedo and odometer readings. and yes if you find a lighter tire with slightly greater diameter you can get btter mpg.
cheers.
Old 08-02-2014, 11:38 AM
13fit's Avatar
tire size does not play a big roll
Again, Im on 205/60/15 PERFORMANCE tires and I can still achieve 40mpg
That I think is nearly an inch bigger (taller) tire and much wider.
DRIVING STYLE, tire pressure, and engine upkeep are VERY big factors!
Old 08-02-2014, 01:15 PM
mahout's Avatar
Dowhill no traffic and 40 mph tailwind, or on flat level road with steady speed, yes, but as soon as you have acceleration, up and down hills, the heavier and larger diameter loses. We've had owners here try and in every case they lost up to 5 mpg and a second in quarter mile.
If you got 40 mpg with 205/60x15 what would you have gotten with 175/65x15's? Its a comparison, not absolute number.
Old 08-02-2014, 10:16 PM
13fit's Avatar
i said it doesnt play a BIG roll. it will make a minor difference.
Ive had larger tires on since about 15k miles. im now touching 40k miles.
I resent people saying no when I drive everyday and achieve great gas mileage.
Hell I can beat the crap out of my casr for an entire tankful on backroads and still achieve 30mpg
take care of your car (tire psi, fluid changes, brake inspections, etc) and you can achieve great things out of it.
EDIT i run a 16.3 in the quarter mile with these bigger tires. I grab 4th for about a second before hitting the finish line
Old 08-02-2014, 11:41 PM
SlowFit13's Avatar
16.3 is impressive for this car, what was your mph? Have you tried leaving it in 3rd and banging the limiter across the line?
Old 08-03-2014, 12:13 AM
13fit's Avatar
I get a 16.6 I think if I bang on the rev limiter and dont shift into 4th.
the bigger tires helped a bit. They take a bit more to top off third gear, yet I still got like 85mph trapped since I am in 4th gear for such a tiny time.
Im changing my 205/60s to 205/50s when I can afford them. The fronts are worn due to all the abusive and curvy backroads I like to enjoy. Rear tires are fresh looking, and will get me through the winter
Old 08-03-2014, 01:06 AM
Everything you post is invalid, I've pushed time and time again for you to post specific numbers, but each time you just say "Oh its 40 MPG"
Tires are a big factor, if I put BFG Rivals on my car in place of my LRR OEM Hankooks, but drove exactly the same/kept the same pressures (38 PSI all around), and maintained at current rates...my MPG would suffer drastically.
Same can be said for making them much taller/wider.
Old 08-04-2014, 11:34 PM
Odie's Avatar
Steve244 , are those the Energy Saver All Season or the summer E.S. ? Thanks
  #32
Old 08-04-2014, 11:38 PM
Odie's Avatar
Do the weight of tires impact gas mileage ? For example the Energy Saver are 14.81 lbs. and the Uniroyal Tiger Paw Touring are 17.64 each . The Dunlop SP31 A/S ( O.E. ) are 16.6 lbs. . These are 175/65-15 .
  #33
Old 08-05-2014, 06:37 AM
What do you guys think about the Michelin premier a/s? They come in 185/55/16 for the sport-
  #34
Old 08-05-2014, 09:59 AM
Steve244's Avatar
Mine are the summer tires (that's all they offered at the time). Next time I'll try the all seasons. Here it doesn't make much of a difference, but even the summer tires performed ok in the ice storm we had last winter. Better than other drivers' all seasons. Could be the driver
  #35
Old 08-05-2014, 10:10 AM
Steve244's Avatar
It requires more energy to spin-up heavier tires. More than if you just added 12 pounds to the car, and not the wheels. So yes it should affect fuel consumption. Not sure how much. Not much. Lighter wheels/tires payoff in performance more than shaving the same weight anywhere else. Tuners go to a lot of trouble to get lighter crank pulleys and flywheels to reduce rotational mass. They're not just blowing smoke.
But the real energy savings come from reduced friction, the "low roll resistance" (LRR) designation.
I saw an increase from 33mpg to 36mpg driving freeways 70%, city suburban roads 30%, tank for tank running the same tire pressure (33PSI). Over the life of the tires (50K) this equates to a fuel savings of $445 @ $3.50/gal. Not much but it more than pays for the premium tires and they last longer, perform better (compared to the stock Dunlops).
  #36
Old 08-05-2014, 11:32 AM
Blocks of wood perform better than the stock Dunlops.
  #37
Old 08-05-2014, 11:40 AM
mahout's Avatar
2 pounds wont be noticable.
At least not to account for a 3mpg loss
2 Lb per corner is a total of 8 lb and at a radius of about a foot the torque loss is 8 lb-ft. If you think thats not noticeable when you only have 130 lb or so max and much less at 2000 rpm, you are sadly mistaken. Like he said, an mpg loss of 1-3 mpg is typical.
The more effort you make your engine use the more fuel.
  #38
Old 08-19-2014, 10:18 PM
luismycorreo's Avatar
Originally Posted by luismycorreo
I'll confirm that you say soon, moved today from std Dunlop 185-55-r16 to General Tire G-MAX AS-03 205-50-r16, the wheels changed too from STD Honda 2013 Sport 16' to Mugen XJ 16'
Luis
3 weeks after and the meter is still in 8.7Lx100Km , no changes
Things to consider:
- Mugen Wheels suposed to be performance designed
- Same with the G-MAX AS-03
What can I say
The stability is incredible, I feel my car very different than before.
Luis
  #39
Old 08-19-2014, 10:59 PM
timemachine's Avatar
After my change from the stocks dunnies to my Kumho 4x 205 50, I can only get 31MPG at best
  #40
Old 08-22-2014, 09:56 PM
Spacecoast's Avatar
Has anyone tried 195/55/16 on fit sport? There is a lot more options in that size
Been running that size for a few years. I would never go back to the stock 185 width. Getting ready to install Firestone Precision Touring soon
Quick Reply: Tires Really Do Affect Fuel Economy
