For my tire gurus!
Old 08-17-2014, 09:42 AM
Gunnar_spess's Avatar
For my tire gurus!
Alright well I'm torn
16x7 + 40
Or
15x7 + 40
Which wheel size would you personally recommend? Why? And if I'm lowered on coilovers, what size tire and I using if I drive the car hard.
Old 08-17-2014, 03:57 PM
Bisquick's Avatar
What are you goals for the car?
PS... I live in Henderson.
-bix
Old 08-17-2014, 05:24 PM
There's a huge wheel/tire thread. Search n check it out. Helped me out when I purchased my wheels. Good luck.
Old 08-17-2014, 08:27 PM
-bix
Perfect!
I want to create the ultimate daily....a drivers car. Great on gas but even better in the corners. And as you know a tire good for here in vegas.
Old 08-18-2014, 10:16 AM
yah, and those are wheels, not tires.
that said i would get the 16x7 between those two. 15's are too small on a GE imo.
Old 08-18-2014, 12:54 PM
Technically those are rim measurements; rim + tire = wheel.
Being in sunny Vegas, 16s all the way (15s do look a little small and frumpy). Go for light weight rims, which translate to forged, which translates to $$ but the little 1.5 thanks you in advance.
Old 08-18-2014, 12:58 PM
Waiz's Avatar
Administrator
205-50-16 is my suggestion, that's what I'm going to next
Currenty on 16x7.5 (+42) with 195-50-16
Old 08-18-2014, 03:05 PM
+1 on the 205/50/16. thats wat im running right now on 16x7 ET40. no rubbing lowered on swifts -1.5 camber on front.
Old 08-18-2014, 08:17 PM
Thank you for the heads up that those are the size of the rims, I had no clue!
Now after finding out how big the rim should be , I'll go with a 16x7....lowered on coils a proper tire size. THEN I'll know the size of my "wheels" thanks for the help.
Old 08-21-2014, 11:54 AM
Probably more than what you want to know but read this and you WILL become a rim/tire/wheel guru.
There are 4 pages/topics
Car Bibles : The Wheel and Tyre Bible Page 1 of 4
Then come here and play imaginary tire sizing to see how it affects you.
Tire size calculator
A lot of traction is nice and all but if the car does not have enough power (FWD to boot) you can't power your way through a turn, it becomes moot. Be real with yourself and ask if you want show, performance, or economy setup? It's a tough question to answer but it greatly impacts how much you spend.
Old 08-21-2014, 09:36 PM
Bisquick's Avatar
I just purchased some H&R springs with a RSB and camber caster bolts. I put some Dunlop Direzza ZII's on and the thing handles great! The next step would be all out suspension, but I still use my car to carry stuff and people.
Old 09-21-2014, 12:07 AM
That's what tires I thinking about...I don't care about looks, I want to hurt feelings at the auto x track. 15x7 rpf1s, either 195or205 50/15s those direzza are nice . Where in Henderson are you? I'm in north.
Vocalkiller
09-22-2014 08:27 PM
Gunnar_spess
08-22-2014 04:51 PM
De36
02-25-2014 09:17 PM
Splater
03-15-2013 12:51 AM
doitdub
07-31-2011 04:25 PM
Quick Reply: For my tire gurus!
