GE8 Tuner
Old 08-23-2014, 01:50 PM
De36's Avatar
GE8 Tuner
I stumbled across this today,TryForce Power Effects ECU. $884 USD. I'm going to send an email to inquire whether it is USDM compatible and the full function of it.
Description:
This setting is to maximize a dense engine control technology of Honda.
 High response specifications corresponding to the circuit from the street regardless of the significant power-up.  ● Reburimitto basic settings: (can be set depending on engine specifications) 7000rpm  no change: ● VTEC switching rotation speed  ● fuel injection quantity: optimizing correction  ● ignition: optimizing correction  ● knock gain optimization:  ● electronic control throttle: optimization  ● immobilizer: Supported  ● Speed ​​limiter: 300 km / h  (90 ー C. Normal ON 93 ℃ キ OFF) ON 85 ℃ キ OFF 80 ℃: ● electric fan operating temperature change    any settings are possible depending on the specifications of the cold regions, such as.  ※ maximum output difference at the dyno pack in GE8-6MT is the normal ratio maximum 10ps improvement.
Tryforce company トライフォースカンパニー 【フィット】コンピュータ パワーエフェクトコンピュータフルスペックECU
Old 09-02-2014, 12:56 AM
Orcshine101's Avatar
this is a great find
Hope it is usdm compatible. Keep us posted!
Old 09-02-2014, 09:52 AM
De36's Avatar
They still haven't responded. Maybe I will try again.
It's not a new ECU. You send them your ECU and make a list of your mods and usage (DD, Track car...). They program the existing ECU; so I would think the software they use should be compatible.
Old 09-02-2014, 11:23 AM
13fit's Avatar
Would be nice to remove speed limiter, increase redline by 3-400 rpm, decrease fan temp switch point operation to maintain under 200*F, allow for slightly more ignition timing, and lower vtec crossover by about 200-300 rpms
Also would not hurt to allow generic 2.5inch MAF tube!
Old 09-02-2014, 01:00 PM
carcrazy003's Avatar
that!
dantok
04-22-2018 02:08 AM
Sprocket
11-14-2013 11:01 AM
bryz_
02-20-2012 06:30 AM
MSILVEST04
11-27-2011 09:37 PM
GrocerySnake
08-13-2010 02:35 AM
Quick Reply: GE8 Tuner
