using Autolite sparkplug in 2010 Fit.....bad idea?
Old 09-16-2014, 11:47 AM
Blackberry Goose's Avatar
My wifes Fit Sport has just over 130k on it and has never had any issues other than the valve recall. Having an independent shop change out the plugs as well as brake fluid, transmission fluid and coolant.
I know it costs more to have a shop do it vs doing it yourself but the pricing he gave me was pretty high. I had him call some other parts places and said he got the price down with Autolite OE plugs.
Is there a downside? Dealer quote I got was only a little more and I'm guessing he'd use the OEM plugs
Thoughts?
Old 09-16-2014, 12:06 PM
Answered my own question. Dealer will do plugs for same price as Indy with OEM parts. Going to go that route.
Old 09-16-2014, 03:18 PM
Steve244's Avatar
They should also be doing a valve clearance check unless the valve recall work was done recently.
Old 09-16-2014, 07:47 PM
hspatz's Avatar
I agree. Even if they make no noise. Some could be tight. It is very easy to get to the plugs with the intake manifold and valve cover off as is necessary for valve clearance adjustment, so you should save some labor on plugs if you opt for valve adjustment as well.
RainierV
11-03-2018 06:54 AM
OLAH17
07-03-2015 08:20 AM
gkitf16
06-15-2015 12:18 AM
hogwylde
08-14-2011 07:35 PM
I like being Fit
02-23-2010 12:22 PM
Quick Reply: using Autolite sparkplug in 2010 Fit.....bad idea?
