2nd gen Fit reliability
#121
Our reliability stats for the Fit now include owner experiences through March 31, 2014, making them nearly a year ahead of other sources.
Repair frequencies, in terms of repair trips per 100 cars per year:
2013 Fit: 4, low
2012 Fit: 3, low
2011 Fit: 5, low
2010 Fit: 14, low
2009 Fit: 13, low
We have two additional statistics, "Nada-odds" and "Lemon-odds", to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop:
2012 Fit: 96, < 1
2011 Fit: 94, < 1
2010 Fit: 87, < 1
2009 Fit: 89, < 1
For the first time I've noticed for any car, every single model year of the Fit is "full happy" on our scale.
Thank you, once again, everyone who has been helping. Next update in August.
For a deeper dive, including the stats for other cars and repair descriptions, and to sign up to help improve this information:
Honda Fit reliability ratings and comparisons
2013 Fit: 4, low
2012 Fit: 3, low
2011 Fit: 5, low
2010 Fit: 14, low
2009 Fit: 13, low
2012 Fit: 96, < 1
2011 Fit: 94, < 1
2010 Fit: 87, < 1
2009 Fit: 89, < 1
#122
We've updated our reliability stats for the Fit to include owner experiences through June 30, 2014 (making them about 14 months ahead of some others).
2013 Fit: 3, low
2012 Fit: 6, low
2011 Fit: 6, low
2010 Fit: 12, low
2009 Fit: 14, low
2012 Fit: 94, < 1
2011 Fit: 94, < 1
2010 Fit: 91, < 1
2009 Fit: 89, < 1
Next updates in November and in February. The more owners participate, the more comprehensive and precise these will be.
For repair descriptions, the stats of other cars, and to sign up to help improve this information:
2013 Fit: 3, low
2012 Fit: 6, low
2011 Fit: 6, low
2010 Fit: 12, low
2009 Fit: 14, low
2012 Fit: 94, < 1
2011 Fit: 94, < 1
2010 Fit: 91, < 1
2009 Fit: 89, < 1
#123
We've updated our reliability stats for the Fit to include owner experiences through September 30, 2014.
2013 Fit: 0, low
2012 Fit: 3, low
2011 Fit: 3, low
2010 Fit: 10, low
2009 Fit: 16, low
2013 Fit: 100, < 1
2012 Fit: 97, < 1
2011 Fit: 96, < 1
2010 Fit: 91, < 1
2009 Fit: 85, < 1
To view the repairs behind these numbers, check the stats for other cars, and sign up to help improve this information (next update in February):
2013 Fit: 0, low
2012 Fit: 3, low
2011 Fit: 3, low
2010 Fit: 10, low
2009 Fit: 16, low
2013 Fit: 100, < 1
2012 Fit: 97, < 1
2011 Fit: 96, < 1
2010 Fit: 91, < 1
2009 Fit: 85, < 1
#124
New stuff this time. We've updated our reliability stats for the Fit to include owner experiences through the end of 2014. Plus we've added reliability trends graphs. These indicate how a model's reliability has changed as it has aged, and how different model years performed when the same age.
2013 Fit: 0, low
2012 Fit: 3, low
2011 Fit: 7, low
2010 Fit: 11, low
2009 Fit: 15, low
2013 Fit: 100, < 1
2012 Fit: 97, < 1
2011 Fit: 92, < 1
2010 Fit: 90, < 1
2009 Fit: 84, < 1
We'll have further updates in May and in August. The more owners participate, the more comprehensive and precise these will be.
To see how competitors compare, and to sign up to help improve this information:
To view the new graphs, select "reliability trends" in the breadcrumbs at the top of the linked page. The trend lines are especially flat for the Fit.
2013 Fit: 0, low
2012 Fit: 3, low
2011 Fit: 7, low
2010 Fit: 11, low
2009 Fit: 15, low
2013 Fit: 100, < 1
2012 Fit: 97, < 1
2011 Fit: 92, < 1
2010 Fit: 90, < 1
2009 Fit: 84, < 1
#125
Perfect reliability here. 101,000 miles!
I just had my first honda checkup... at 100,000 miles. Negligent?... Well yes, I'd admit to that.. I was also on my original clutch and brakes too. The dealer said my back brakes are fine and only my front need to be replaced (though there was still some life in them). I also avoid the 5w-20 oil recommended too. The only 5w-20 oil this car has seen was from the original factory fill. Outside of north america I repeatedly read that Honda recommends heavier oil for this engine. I've used only 5w-30 in the artic-cold Minnesota winters, and 10w-30 in summer without any negative results. I have changed oil, air and cabin filters frequently, and even repalced a windshield (from a rock hitting it). My engine PURRS! i get 35 mpg or better consistantly, and my car is still quite fun to drive. There are a few rock chips in the paint. And only 1 headlight bulb has burnt out in it's 100,000 miles.
You can say I'm happy with the high reliability and it's still a fun car to drive. The shifter still is tight and a joy to use. I regularily take my 09 Fit across the rockies to visit relatives. I reported to the Honda dealer that the car has repeatedly seen 42 MPG in the mountains on straight 85 octaine. The dealer stated that it's probably because they don't add ethanol to the gas in the mountains and thus the mileage increases because the ethanol burns up so quickly in our Minnesota gasoline. My dealer also stated the rear struts are leaking, but not the front. There hasn't been any negative handling effects, so I decided to postpone replacing them.
In short, this car is incredibly reliable and to me, that's the biggest luxury of all.
#126
You've been changing the oil, filters, etc. and have probably kept a close eye on the car, so I'm not seeing any negligence here myself. Happy to hear it's been so reliable--not that this is unusual for a Fit.
#127
Do you mean that it hasn't blown up or did you actually measure the wear on the crank bearing, piston pins, rings, etc?
Perhaps you've worn your engine twice as much as the ones that used the recommended oil viscosity, especially in the cold climate.
#129
So, how have these cars been doing lately?
Our reliability stats for the Fit now include owner experiences through March 31, 2015. (Others are nearly a year behind.)
In terms of repair trips per 100 cars per year ("low" is best):
2013 Fit: 2, low
2012 Fit: 5, low
2011 Fit: 4, low
2010 Fit: 8, low
2009 Fit: 17, low
Plus, the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop:
2013 Fit: 98, < 1
2012 Fit: 97, < 1
2011 Fit: 96, < 1
2010 Fit: 94, < 1
2009 Fit: 85, < 1
Additional participants always helpful. Next updates in August and November.
For repair descriptions, the stats for other cars, and to sign up to help improve this information:
2013 Fit: 2, low
2012 Fit: 5, low
2011 Fit: 4, low
2010 Fit: 8, low
2009 Fit: 17, low
2013 Fit: 98, < 1
2012 Fit: 97, < 1
2011 Fit: 96, < 1
2010 Fit: 94, < 1
2009 Fit: 85, < 1
#130
Our reliability stats for the Fit now cover the year ending June 30, 2015. (Others are over a year behind, and so report how these cars were doing when a year younger.)
Repair trips per 100 cars:
2013 Fit: 4, low
2012 Fit: 8, low
2011 Fit: 4, low
2010 Fit: 8, low
2009 Fit: 15, low
2013 Fit: 95, < 1
2012 Fit: 94, < 1
2011 Fit: 96, < 1
2010 Fit: 94, < 1
2009 Fit: 85, < 1
For the descriptions of all reported repairs, results for other models, and to sign up to help improve this information:
2013 Fit: 4, low
2012 Fit: 8, low
2011 Fit: 4, low
2010 Fit: 8, low
2009 Fit: 15, low
2013 Fit: 95, < 1
2012 Fit: 94, < 1
2011 Fit: 96, < 1
2010 Fit: 94, < 1
2009 Fit: 85, < 1
#131
We've updated our reliability stats for the Fit to include owner experiences through September 30, 2015.
2013 Fit: 4, low
2012 Fit: 11, low
2011 Fit: 11, low
2010 Fit: 15, low
2009 Fit: 17, low
2012 Fit: 94, < 1
2011 Fit: 92, < 1
2010 Fit: 88, < 1
2009 Fit: 84, < 1
For the details, including repair descriptions, and to sign up to help improve this information:
2013 Fit: 4, low
2012 Fit: 11, low
2011 Fit: 11, low
2010 Fit: 15, low
2009 Fit: 17, low
2012 Fit: 94, < 1
2011 Fit: 92, < 1
2010 Fit: 88, < 1
2009 Fit: 84, < 1
#132
We've updated our reliability stats for the Fit to include owner experiences through the end of 2015, about eight months ahead of other sources.
In terms of repair trips per 100 cars per year--lower is better:
2013 Fit: 8, low
2012 Fit: 16, low
2011 Fit: 15, low
2010 Fit: 13, low
2009 Fit: 20, low
2013 Fit: 91, < 1
2012 Fit: 89, < 1
2011 Fit: 92, < 1
2010 Fit: 85, < 1
2009 Fit: 81, < 1
For the repairs behind these stats, reliability information on other models, and to sign up to help improve this information:
2013 Fit: 8, low
2012 Fit: 16, low
2011 Fit: 15, low
2010 Fit: 13, low
2009 Fit: 20, low
2013 Fit: 91, < 1
2012 Fit: 89, < 1
2011 Fit: 92, < 1
2010 Fit: 85, < 1
2009 Fit: 81, < 1
#133
2013 Fit: 91, < 1
2012 Fit: 89, < 1
2011 Fit: 92, < 1
2010 Fit: 85, < 1
2009 Fit: 81, < 1
Guys,
could your report be any more confusing to interpret???
I hope you are doing better job collecting the actual data.
#134
2011 Fit: 92, < 1
2010 Fit: 85, < 1
For an '11 there is a 92% chance of no repairs, and less than 1% required 3+ visits.
For a '10 there is an 85% chance of no repairs, and less than 1% required 3+ visits.
Super simple!
#136
We've updated our reliability stats for the Fit to include owner experiences through June 30, 2016. Reliability information elsewhere is based on a survey conducted in April 2015--well over a year ago.
Repair frequencies, in terms of repair trips per 100 cars per year (lower is better):
2013 Fit: 14, low
2012 Fit: 11, low
2011 Fit: 23, low
2010 Fit: 18, low
2009 Fit: 14, low
2013 Fit: 90, < 1
2012 Fit: 90, < 1
2011 Fit: 79, < 1
2010 Fit: 83, < 1
2009 Fit: 88, < 1
We'll have further updates in November and next February. The more owners participate, the more comprehensive and precise these will be.
2013 Fit: 14, low
2012 Fit: 11, low
2011 Fit: 23, low
2010 Fit: 18, low
2009 Fit: 14, low
2013 Fit: 90, < 1
2012 Fit: 90, < 1
2011 Fit: 79, < 1
2010 Fit: 83, < 1
2009 Fit: 88, < 1
#137
I signed up today, I did a motor swap on my car last month because I got the car with a spun bearing how would I note that, would you want me to wait till I open the engine to register so the fault can be determined at the same time?
radioarno
02-05-2018 11:53 AM
radioarno
02-05-2018 07:18 AM
2006, 2009, 2nd, fit, gen, generation, history, honda, issues, problems, ratings, reliability, relibility, relibilty, repair
