Oil change: how much oil do you pour in
Old 06-23-2012, 01:24 AM
Odie's Avatar
Question Oil change: how much oil do you pour in
your engine? Quarts and ounces. Thanks
Old 06-23-2012, 03:58 AM
bmxman's Avatar
I don't remember exactly since I have 4 Honda's but I think it was 3.8 quarts. you really should consult your owners manual. It has it listed so you know exactly how much to put it.
Old 06-23-2012, 09:33 AM
Carbuff2's Avatar
What I do is, I keep track of the amount required to fill up to the middle of the dipstick's range. Then I write the amount on the emissions sticker under the hood.
At future oil changes I just put the indicated amount into the engine.
There are small variations in oil amounts due to things like which filter is used (some brands are bigger than others) or the slope of the driveway.
Old 06-23-2012, 09:44 AM
Hootie's Avatar
Check your owners manual.
It should be 3.6 qts without changing the oil filter/ 3.8 qts with a new oil filter.
Old 06-23-2012, 01:46 PM
malraux's Avatar
Manual says 3.8 qts. Last change I put in 4 qts, but there was some spillage.
Old 06-23-2012, 06:43 PM
Lance's Avatar
is it okay to have it filled to the top dot?
Old 06-23-2012, 08:10 PM
n9cv's Avatar
Yes. That is the full mark
Old 06-23-2012, 09:07 PM
Carbuff2's Avatar
The reason I don't fill to the top is, it's the additive packs in the oil that become depleted first. (Was told this by a respected Exxon-Mobil engineer who gave a talk at our car club.)
So, I only fill half-way up the range hashes on the dipstick. Many thousands of miles later, I'll top up the oil to the full mark, thus giving the additives a shot in the arm (as it were).
Your engine probably would be fine without doing this, but in my mind it's just like changing the oil filter EVERY time (Instead of every other time as Honda recommends).
Old 06-23-2012, 10:19 PM
evil_s10's Avatar
You should get in the habit of only filling it to the half way mark. The full mark is intended for the engine oil at operating temperatures.
Old 06-23-2012, 10:27 PM
malraux's Avatar
That sounds not right. Beyond which the oil doesn't expand that much from cold to hot.
Old 06-24-2012, 08:33 PM
evil_s10's Avatar
I've personally seen cars that were at the half mark on the stick when the oil was changed cold (let run for 1 minute then check 3 minutes after stopping engine) reach the max mark after driving the vehicle for 30 minutes. Expansion or contraction i've heard doesnt mean anything to engine oil but this is my own personal experience.
Old 06-25-2012, 03:40 PM
nikita's Avatar
4qt, change filter every time. Somehow, even if the manual says 3.8, with 4 it shows just below the "full" mark. The last interval was 7000 miles and the level dropped only about 1/8.
Unless one is extending drain intervals well beyond the MM, I wouldnt worry too much about additive depletion with modern oils. If you are, UOA's with TBN test is recommended. Some of the old myths, like multi-grade oils shearing down in viscosity after 1500 miles, may have been true 40-50 years ago, simply dont apply today. Of course an interesting question is which happens first, additive depletion, contamination buildup, or base oil oxidation. None of this happens in isolation. Its interrelated.
Old 06-25-2012, 06:07 PM
Perrenoud Fit's Avatar
Question Is this a Blond jk?
Till it reaches the top 710 cap.
If it's inbetween the hash marks your okay.
Old 06-25-2012, 06:31 PM
Carbuff2's Avatar
I guess I'm not putting enuf oil in, am I?
LxFit
46
01-09-2018 09:36 AM
Odie
03-26-2014 12:06 AM
DaveFL
01-08-2014 12:19 AM
FitsMePerfect
09-21-2011 03:55 PM
vwli
07-08-2009 07:07 PM
Quick Reply: Oil change: how much oil do you pour in
