replace washer fluid reservoir?
Hi, any simple instructions to replace the washer fluid reservoir on a 2013 Fit? It started leaking after it got bumped in an accident.
Do I need to remove the headlight assembly and bumper to access the reservoir?
Front bumper removal makes it a bunch easier but you MAY be able to do it from the back of the fender going in after removing the plastic fender liner. I don't think the headlight on that side.
The whole front comes off with a few Phillips head screws and pop out clips and if you have even basic skills it is easy to do.
I had the same problem. I did need to drop the bumper. found out I broke the washer fluid motor and not the reservoir. I have a 09 fit, I do think its the same. if you need the reservoir I have one for sale, just PM me
Directions to replace washer reservoir?
Hi! My husband had a minor fender bender and the washer tank won’t hold fluid. I’m thinking it’s cracked. I bought a new one and want to install it but can’t find instructions online. What manual did you find the instructions on? Thanks!
toolboxjesse
02-26-2017 03:04 PM
n9cv
09-23-2014 11:40 PM
