100,000 Mile Maintenance Recommendations
Old 04-05-2016, 08:22 PM
Hondu's Avatar
So I know the maintenance minder show codes for the standard replacement items (plugs, fluids, etc.), but when reaching 100,000 miles, what maintenance would you recommend is performed for a 2009 Fit?
Old 04-05-2016, 08:39 PM
I do my maintenance at shorter intervals than most, but if they haven't been done recently, I'd do all fluids, plugs, coil packs, check brake pads, check any rubber boots/bushings/engine mounts/etc., check the shocks/struts for leaks, etc.
Old 04-06-2016, 07:11 AM
Carbuff2's Avatar
...and adjust valve clearance.
Old 04-06-2016, 08:36 AM
Hondu's Avatar
So how critical is that service? If the valves are not noisy, I thought the manual says you can go to 160,000 miles.
Old 04-06-2016, 09:11 AM
Carbuff2's Avatar
Typically, the exhaust valves TIGHTEN. (decrease in clearance) They will NOT make noise if tight.
The consequence would be misfires or burned valves.
BTW I thought the service schedule said 110K miles for checking valve clearance. We've checked them twice on our GD (at 60K and 115K), and several were out-of-spec each time.
Old 04-06-2016, 12:18 PM
dwtaylorpdx's Avatar
I personally believe the short coil life is a result of the lack of a valve adjustment, it causes a loss of compression and the spark needs more current to jump the gap if the compression is lower.. Overworks the coils.
Old 04-06-2016, 08:11 PM
Hondu's Avatar
Any recommendations for plugs and coil packs? What is a reasonable price for a valve adjustment, spark plugs and coil packs at a dealer?
Old 04-06-2016, 08:29 PM
Carbuff2's Avatar
You will pay thru the nose both for parts and labor at a dealer.
Aftermarket, the OEM Denso plugs are around $8.50 ea USD, and the coil packs (Hitachi with the part number ending in 053) are around $40 each. (This, from Rock Auto)
Best to find an independent Honda specialist near you to do the work if you don't weant to DIY. 'Specialist' is the key word. You want a repair facility either with HONDA in the name [EG, "Joe's Honda Repair"], or a back lot FULL of Hondas and Acuras.
Valve Adjustment is a labor thing (no parts are usually needed), so since labor rates vary, best to get a quote or two.
Old 07-19-2017, 10:25 AM
PaceP's Avatar
I'm looking at a 2010 with 105K- probably going to do this. I also heard that the pressure sensor for 2nd gear in an AT would need changed as well. Thoughts?
Sonnington
03-29-2018 07:32 PM
ikutoisahobo
09-19-2017 01:35 AM
Farrago
10-24-2016 08:37 PM
ten_year_man
05-25-2015 10:14 AM
Shora
03-11-2009 02:21 AM
Quick Reply: 100,000 Mile Maintenance Recommendations
