View Poll Results: Will your next oil change be 0W-20 or 5W-20?
OW-20
76
64.41%
5W-20
42
35.59%
Voters: 118. You may not vote on this poll
Poll: who's switching to 0W-20?
Finally voted in my own poll. I'm going with 5W-20. Unless you assume a totally awesome Group 4 base stock synthetic with no viscosity modifiers, the greater the range between the two numbers, the more of those chemicals there are to break down. Besides, the switch from 5 to 0 is likely to get Honda's fleet some small percentage point of a mileage gain for CAFE purposes, but not make a real difference in my car.
That's not to say I'll NEVER try 0w-20. The poll says "next oil change". I'd try it to satisfy my curiosity.
I've developed a little oil obsession over the past week or so and the biggest thing I've learned is that no one agrees with anyone else on the internet about anything, period. Even the "experts" are crazy. Bob the Oil Guy? Tears apart his new Ferrari when switching oils so he can get all the old stuff out of every nook and cranny (rather than say, flushing it). Motor oil Bible? Secretly contains a real Bible. Seriously, it's like it's the middle ages, but we all have internet forums to spout off about alchemical formulas.
If you guys want more mileage and / or power from your oil, try running a little less oil...
Wet sump motors have the crank's counterweights sloshing through a pool of oil. Imagine running down the beach. The deeper you're in the water, the harder it is to run. I'll bet you'll be able to tell more difference between the top marker on the dipstick & the bottom marker than you will between a 0W20 vs a 5w20.
Caveat.... The motors likely rely on splash lubrication for the clyinder walls (unless they have oils jets - I dunno). But the bottom mark should be safe - that's why it's there.
-Saro
-Saro
Saro where did you get this info? I would think more oil would run cooler than less oil. On my 95 geo prism I always fill it a half quart above the full line and I am over 150,000. Not sure I will do this on the fit ...maybe just a quarter of a quart over. Of course I am the guy that found it hard to believe 10-30 was recommended let alone 0-20 on the fit. add to that finding out replacement keys cost over a hundred....I am old but not that old!
I was looking around to find the differences between 0w20 and 5w20 and found that they are the same except for the temps which is colder for 0w20 than most will ever see. http://www.infineum.com/Documents/AP...ils%202010.pdf
-Saro
-Saro
SilverBullet-
That's really interesting that the Honda cranks don't ride down in the oil anymore. I have no service manual or anything (so didn't know for sure about the oiling system) but how deep is the sump that the crank stays out of it?
-Saro
-Saro
Oil scrapers are used and the old v-8 didn't have them unless you fabricated them. If you look at the pdf file you will see that the crank sits higher with a oil scraper.
Silver Bullet-
If I'm not mistaken what you're looking at is the stuff to install a dry sump system on the L15 motor - especially since the motor is now approved for what used to be the Formula Ford class. But it's late, I'm tired, and I'm not reading the whole pdf!
-Saro
-Saro
#32
There is a reason, but its not all about CAFE. The temps that 0w20 is better 99 percent of people would never see. 0w20 M1 is the only oil I would consider because of past experience. I think it has to do with additives and how easy to make now compared to the past.
#33
Silver Bullet-
-Saro
-Saro
#34
Well,
My 09 says use 5-20...but car just rolled 15000 miles...i bought it used so not sure how much, or often it was done...at least 1 or 2 times....my parents hardly drove it, so it sat alot. The oil change sticker from dealership said to change it last month, but oil life meter says still has 70% left.
I am slowly going through doing maintenance....oil change is first up since I just put on some new wheels and put in a K&N filter
Then brake fluid, and maybe the plug upgrade. I have been averaging 32-34 in mixed commuting, but took a couple of 90 mile drives on highway...70 mph, cruise control, and a/c.....calculated 45 mpg on fill up....
#36
Hopefully everyone can see that the differences between grades is just not that big. People really get hung up on these things, yet our cars dont have an oil temperature gauge. Toyota has recently gone from 5W-30 to 0W-20 in most engines, not just hybrids where it started. Bearing clearances didnt change, just future CAFE standards.
Some automakers are lobbying the SAE to add even lower viscosities to the standard, especially in HTHS, where mileage gains, and valve train wear are the most critical.
#38
You beat me to it. Thanks for posting what is a nicer presentation of SAE J300, the motor oil viscosity standard since the 1920's.
#39
2011 base model Fit w/ 5 speed auto : Honda Genuine 0w-20 ( SN/GF-5 ) which is produced by Kendall . Next oil change debating the Pennzoil Platinum 0w-20 , Eneos 0w-20 , Kendall 0w-20 w/ titanium or maybe Amsoil ( true synthetic ) . Which one ? . So many good choices . Plan to get an Used Oil Analysis ( U.O.A. ) of the Honda Genuine ( Kendall ) and will post the results .
#40
