Sponsored by:
Sponsored by:
Do you think a bra would
Old 02-12-2014, 08:41 PM
hardwood28's Avatar
cut into the mpg, I got one that came on my 2009 sport fit.
Old 02-12-2014, 09:44 PM
2010FitSport's Avatar
Most likely would since its seems slightly less aerodynamic than just the body would be.
I read on a Prius forum about people getting better MPG by doing some grill mod with cardboard to deflect more air over the hood and not through the grill. It wasnt just one post. There were a lot of people experimenting with it.
The point Im tryng to make is that it doesnt take much to change airflow over the vehicle and any areas of the bra that are not flat, including those little raised sections that some bras have could change the aerodynamics.
You could always do a test with it on and off for a tank and post the results
Old 02-13-2014, 04:52 AM
ClaytonLeton's Avatar
I need that too...
Old 02-20-2014, 11:11 AM
Fit Charlie's Avatar
A grille block is a pretty standard modification for increasing mileage. It cleans up the airflow at the front and helps the engine warm up faster. It's on my List of Things To Do.
Old 02-21-2014, 03:16 PM
fireemt24's Avatar
also makes your car over heat if you aren't running a cai grill modd on a fit would be minimal increase in mpg if any
Spacecoast
10-08-2009 10:35 PM
prez187
04-17-2009 12:10 AM
iKONA636
34
03-13-2009 12:08 AM
ABuckFitty
03-20-2007 12:53 AM
sLiVeRwOrM
05-20-2006 12:18 PM
Quick Reply: Do you think a bra would
