does 2013 base model have a built in amp?
Old 04-28-2015, 03:12 PM
amintha1992's Avatar
so i removed the OEM head unit so i can do a nexus 7 install on it.
i was planing to use a small amp that i have to power the speakers. but after reading some stuff Im confused if the car still have a amp separate from the CD player and the FM unit that i just pulled out.
i just hooked up a couple of wires from my phone to the front Left speaker through the harness(i did not cut it, just jammed the wires in to the pin holes)
and i could hear the music ever so slightly from the speaker.
my question is, does my car have a amt that has to turned on with the remote amp turn on wire and how much voltage i have to put through it to get it to work and not burn anything out.
thanks
Old 04-28-2015, 06:37 PM
DrewE's Avatar
The amp is built into the head unit; there's no separate amplifier. What you're hearing is just the headphone amplifier on your phone powering the speakers in the car. Since this is not a very powerful amplifier, you don't get a great deal of volume. (The headphone amplifier might max out at something like a quarter watt per channel. That means it can produce roughly 25 or so dB less than the factory radio through the car speakers—not too loud, but certainly audible.)
Old 04-28-2015, 06:56 PM
thanks you Drew, yes i knew why i could here the music when i connected the phone, i was not sure if it was because the amp was turned off.
now its all cleared up. ill be hocking up a amp to the setup.
thanks again.
Old 07-14-2015, 04:12 AM
Elias Paniki's Avatar
hi, did I just read that correctly? You're installing a Nexus 7 in place of your stock HU? Would you mind posting some pics? I have a nexus 7 just lying around and is planning to make it a mainstay in the car to act like a cheap audio system that looks a bit cool. 'Cept that I'm stumped with ideas other than letting the tab sit down in the middle with an AUX plugged in.
FyrFytr
04-10-2012 12:46 PM
hiwatt357
11-24-2011 07:57 PM
potentialFITfan
11-04-2010 06:10 PM
specboy
10-19-2009 07:42 AM
Young Fledge
Greater Calgary Community
07-14-2008 12:28 PM
Quick Reply: does 2013 base model have a built in amp?
