Steering wheel controls using aftermarket radio
Hi All,
I'm in the process of replacing my factory audio player with an aftermarket one. The new player comes with a wiring harness which plugs into the original socket, but the following wires needs to be connected manually, outside the harness.
1) Steering wheel controls (wires KEY1, KEY2 and GND on the new player). Which wires in the factory socket should these be connected to ? Also do i need a stalk adapter like the one given below or will a direct connection work ?
https://d11tezxtmr089.cloudfront.net...s/CTSHO003.jpg
2) BREAK wire
3) REVERSE wire
Any idea which wires in the original socket should be plugged into the above in the new player ?
Thanks
2) BREAK wire
3) REVERSE wire
Thanks
Xitomatl
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
08-20-2019 01:46 PM
connor55
06-18-2012 09:33 PM
Mugen_Dom
09-21-2007 04:16 PM
