eternal_fantasy's TWDM GE8
hey eternal_fantasy
whats your take on a full - coil over versus buying them separately .
swift springs for front/rear and spoon as my damper?
I am looking at eibach pro street S coilover or do what you did
I am looking at spoon as my damper and swift for spring...
The only reason going with Swifts for me was being able to tune the Fit to my desired F/R roll resistance and ride frequency, whilst achieving "flat ride". I was able to get away with raising the spring rates because I felt the rear Bilstein dampers were overdampened in the first place, and the front TEINs can be adjusted to control the higher spring rate.
There are huge hassles combining different sets of spring and damper, such as full damper droop length compared to spring's free length, spring seat size and design between different spring designs, adjustable spring seat for the rear etc., all of which a coilover kit have it figured out for you.
So unless you desire the freedom of a fully custom spring rate setup, and all the associated trial and error/taking measurement/working out all the gremlins, I'd suggest a set of coilovers that is closest to your desired rate and design (Mono/Twintube/adjustable etc.), and swap out one end of the spring to achieve the desired handling balance.
great car/ thread, feel like I'm learning a lot just watching.
have yet to pull the trigger on coilovers, but am planning on getting soft ground controls using stock dampers. wondering if the ground controls will be captive springs or not...
The Insulation was a thick carpet like fibre material I got from an sound insulation shop. It looks and feels pretty much the same as the material for the firewall insulation from factory.
My GPS mount is the Garmin rubber mount, but with its rubbery base removed, and stuck onto the dash with some 3M double sided acrylic tape. I'll get a picture of it from the side for you. Power is just rerouted through the dash, coming out near the center console cup holders, and plugged in the 12V.
Some update on the rear suspension setup.
Using Stainless Steel wire ropes and some swaging I was able create a device to limit rear trailing arm travel without modifying the damper, thus eliminate the need for helper springs, which was causing some weird behaviour from trailing arm deflection during turns and bumps.
The rubber isolator for the Bilstein rear adjustable spring perch was modified from Honda factory part, which provided much more surface area compared to the Bilstein part.
The ropes have a 290lbs working strength and 1450lbs breaking strength per side, so should be plenty strong for the application.
also can you talk about the top mount for the straps.
thanks
Looking at the GC kit it seems that they will select a set of springs for you once you tell them the dampers you will be using and the type of driving your suspension will experience, so I think they will make sure that the springs will not fall out at full droop (I hope). It seems a little confusing for me as I wouldn't know exactly what I was buying from GC... You'd just have to have faith in them I suppose
I was looking for a location for the top attachment point, and the only spot I could find was a 20mm hole along the frame of the chassis. So basically the wire ropes goes around a short stainless tube inside nylon reinforced hose, identical to the one in the picture, that was inserted into the 20mm hole, rotated, and rests horizontally inside the chassis frame. The wire rope is then pulled down, and second steel tube inserted into the top strap loop, sandwiching the chassis frame's sheet metal in the middle of the two tubes, in turn secures the top of the strap.
I guess a picture really is worth a thousand words...
Some PU hose was cut to provide abrasion resistance for the wire rope against the chassis frame hole edge.
Admittedly some finger agility was needed to seat the top tube properly, but a tool was made to make installation much easier.
hey thanks for the info, I will talk to ground control. Ideally I will end up with captive springs. but if i don't, at least i always know i can do this. thanks so much
Man your skills at both designing and install are incredible!
cheers!
cheers!
Thanks Space Egg!! The stock dampers have really long stroke, so I'd think you'd run into captive problems using anything higher then a 3kgf/mm spring without shortening the damper or find a way to limit spring seat travel.
Thanks! I made the straps myself. Ordered parts from Amazon, took some measurements then got to work swaging. The cable size was just on the limit of what you can safely swage by hand tool. Took me 3 attempts to make them just the right length for a snug fit on the spring seat. each strap took around 30 minutes to make, so wasn't too bad I guess.
#32
I've ran out of wire rope making prototypes of the strap. If you guys want some made, one of you can send me the , which I originally imported from the US, and two packets of
, and I'll make you guys some for the cost of the rope + sleeve (basically for free as I'll have the unused material as payment), and I'll throw in the mounting stainless tubes for free.
#33
I've ran out of wire rope making prototypes of the strap. If you guys want some made, one of you can send me the wire rope, which I originally imported from the US, and two packets of crimping sleeves, and I'll make you guys some for the cost of the rope + sleeve (basically for free as I'll have the unused material as payment), and I'll throw in the mounting stainless tubes for free.
thanks alot
#35
that's fine i'll make a tool to fit it in there.
#37
I'm running McGard wheel lock lug nuts, and Rays Hub-centric rings. There are pictures of the rings in the first page.
BMW ALPINA
108
08-26-2019 02:00 AM
ViRStephen
01-17-2019 03:53 PM
