Buddy Club Extended Ball Joint Install
I was thinking about the j's racing one's ,
http://www.j-sracingusa.com/jsusa/ga...BADJ%2D1%2Ejpg
Nice write up. Here's a third company offering them, hardrace. Not sure of the cost but might be helpful if someone was shopping around and wanted to check with them.
HARDRACE - Performance Suspension Parts
I got an email from Hardrace.
They offer control arms with hardened inner bushing (6894). And optional extended ball joints, control arms and hardened inner bushings installed (6895) so the just bolt on.
Or you can save yourself some $$ and buy the bushings (6808) and joints (6881) separate reusing your control arms.
They offer a 25mm shorter sway bar end links (6891), which is probably my next suspension mod.
A US sales person was suppose to contact me to talk price but I never heard from them.
Look one post above yours.
I got a hold of the main supplier but he would talk prices, just product. He said a US sales rep was going to contact me. I will try the US sales rep again.
Hi, i'm looking to buy the buddyclub roll center adjuster but i have a question for you guys:
I'm running on a set of Enkei RPF 1's with 1950/50R15 tyres and i was wondering if the kit will fit without rubbing on the tyres or wheels?
What do guys think?
What do guys think?
I can throw my 15 steelies on and see if they clear. But I cant do it till next Wed. I will keep you posted. If I forget PM me.
Does those roll center adjusters stand the test time?
And do you know a company that make polyurethane bushings for the GE?
As for the poly bushings, I don't recommend it for a street car. I had ALL poly in my SpecV and I was way to harsh of a ride. In the WRX I went with hardened rubber bushings and it was the best of both worlds.
For control are bushings:
I don't know know how long a unit measured "test of time" is, but they are made by Buddy Club Japan, Its quality stuff. Having the OEM and BC joints in my hand at the same time, Im confidant in saying that BC are much higher quality than the OEM.
Well, i'm not using daily driving the GE that much now, so i'm still hesitating between poly bushings or hardened rubber ones. Nonetheless i really appreciate the info!
For now, i'm just waiting for your confirmation about the fitment of the buddyclub's on 15 inch wheels and i'm going to get them.
#32
https://www.fitfreak.net/forums/2nd-...ersion-13.html
The idea here is to lessen un-sprung weight. Using that money and put it into lighter wheels and tires to lessen un-sprung weight, you would yield bigger handling gains.
Also aluminum is more flexible than steel, so steel wins in stiffness. And you can't replace the ball joints on aluminum arms, so you will not be able to install the extended ball joints, steel wins again.
J's racing even uses steel arms. The Insight is a grocery get-er, how stiff could the control arm bushings be? It's rhetorical.
With steel you can have extended BJs, hardened bushings and stiffer control arms. OR aluminum you can save 8 lbs of un-sprung weight. It's obvious which set up would handle better on the track.
Note: I am not belittling un-sprung weight, it is very important important when it comes to handling.
#34
I just finished emailing Sprintex last week. They just finished a batch of 12 that are already sold. They told me to check back at the 1st of the year.
#35
Hi, Chris.
I’ve got Honda kits completed now. Not all of them are spoken for. If you would like one, please let me know.
Regards,
Gary Turner
USA Coordinator
www.SprintexUSA.com
[IMG]file:///C:\Users\CHRISE~1\AppData\Local\Temp\msohtmlclip1\ 01\clip_image001.jpg[/IMG]
Sprintex Limited (ASX: SIX )
ACN: 38 106 337 599
USA: 1-855-591-2778 or 1-405-658-9288
13613 Eskridge Dr.
Oklahoma City, OK 73114
F: 1-405-749-0014 (USA)
W: www.SprintexUSA.com
E: GTurner@SprintexUSA.com
T: + 61 8 9262 7222 (AUS)
#36
I emailed them Dec 11, 2 days earlier.......
Hi, Doug.
Our Honda kit is becoming available, now. It produces 5psi of boost and makes about 180hp at the crank. We’ve got a cleaned up tune that is running well on 91 octane gas. No dyno report on it yet, though.
Retail price is $2,995 with the SMT8L PerfectPower tuner included.
These first 12 are spoken for. Contact us again after the first of the year and the second batch should be on the way.
Kind Regards,
Gary Turner
USA Coordinator
Sprintex - Superchargers and Supercharger Systems | Increase your power and torque with Sprintex Superchargers
Hi, Doug.
Kind Regards,
Gary Turner
USA Coordinator
