Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes > 2nd Generation GE8 Specific Wheel & Tire Sub-Forum
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-19-2009, 11:14 PM
danielg's Avatar
danielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to livedanielg relies on Rep Points to live
Send a message via AIM to danielg Send a message via Yahoo to danielg
unOfficial Q & A for aggressive fitment
**First off, I have a GE, as of right now, all references are towards a GE - If someone w/ GD in Norcal wants to meet up, I'd be happy to take measurements and put them here too. For the most part, all the stuff I'll be going over is pretty general - but specific measuremets and references and for specific vehicles.
I'm here to help any and everyone with aggressive fitment. Whether it be your Honda GD, GE, your civic, your wrx, your bimmer, your moms van... Whatever.. Aggressive fitment isn't rocket science. There's math involved, but you don't need to work for NASA.
The most important things one needs to realize is that:
1. Everyone's opinion of aggressive wheel fitment is subjective. Go with what YOU like. If you want it so that you're a couple MM behind the fender, almost flushed, but tucking - do that. If you like flush - do that. If you like poke, stretch, camber, roll/pull - do that. It's your car...do what YOU want.
2. Even with a roll, stretch, pull, camber, etc. You might still rub. Actually, you'll rub until you've 100% nailed the fitment. Even then, you might still rub.
3. Don't expect to bolt the wheels and tires on and go. If, at a minimum, you can't/wont/dont want to roll the fenders, it's not for you. MOVE ON.
4 Aggressive fitment is work and time. If you don't have either, pay someone or MOVE ON.
5. Remember, you might rub.
6. Don't rush on anything. Make sure you double checked your measurements and math. Don't just buy wheels because they are low offset. Dont half ass or mickey mouse anything. You'll save yourself from headaches, and it'll look better.
7. Have fun!
8. Did I mention you might rub?
I'll go into more details of fitment later - I have to run to a dinner. For the time being check this out.
Below is a post from my build thread (insert shameless plug here)
http://www.fitfreak.net/forums/fit-p...ld-thread.html
Quote:
....Some teasers and GE wheel fitment I promised.
The tires are pretty big. I got em like that. I think I'm going to run 215/35s - Possibly some 205s but I have order them from Japan. To be honest, I think I can get the 225/40s to work, but I'm being lazy.There's maybe 4-5 MM between the fender as it sits now (already rolled, very very slight pull). If I give it some more pull, and get rid of the tab holding the fender to the bumper, should be fairly easy...or If I get some camber bolts and add a couple degrees should be fine.
Here's to the people who say 225 are too big.
Personally, I don't like big tires. But hopefully the pictures below will help some of you out.
These are 18x7.5 +40mm 225/40/18. They are several MM away from being flush. What's awesome is that based of this fitment, my initial measurements for BAD ASS fitment were correct....
...so to anyone who's going air and/or wants specs for custom orders....
For perfect specs (**My opinion**), the below fitment will sit just a bit outside the fender. Personally I dont like flush, I like just a bit of poke. Don't expect a "walk in the park fitment" with these numbers, but if you want it how I like it then here you go.
__ X 8 +30 standard disk
__ x 9 +30 low disk
**For the rear wheels, if you're going to go outside of those specs, you'll have to be careful with the offset and allignment specs you choose. There's not a lot of inner clearance, and you'll hit the strut before you know it...if that happens, you'll try a spacer, but that will only have you hit the quarter panels, then you'll try to camber with a shim or something, then end up hitting the strut again.. It's pretty tricky in the back. HTH***
So there's to all you @$$holes that dont give out your specs because its a "secret offset". bullshit. ANYONE can figure out offsets. I F*&%ing HATE people that say offsets are private and all that non sense. I hope those specific people from other forums read this. If you're one of them, jump off a bridge and die. People like me, who are here to actually help people, clean up your rambling all the time.
Anyways on to the pics. Sorry for the negativity. With that being said, if you need help with wheel fitment, just ask me.
/end rant
MOAR PICS
On a side note. 18's are AWESOME on the new fit. 16s were waaay to small imo. The car is big (like the scion xb) and 18s work out awesome. I think you could get away with 17s if they were really aggressive.. then again, if you're tracking, 16"s are where it's at.
Sponsored Links
  #2 (permalink)
Old 09-19-2009, 11:16 PM
danielg's Avatar
saved for later
  #3 (permalink)
danielg's Avatar
Another one for later
  #4 (permalink)
Old 09-19-2009, 11:17 PM
danielg's Avatar
and maybe one more for good measure
  #5 (permalink)
Old 09-20-2009, 12:21 AM
SD_MR_FIT's Avatar
SD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to live
Send a message via AIM to SD_MR_FIT
yeah ill soon need your help. i just picked up a pair of cv pros 3 piece 15". and i need to order new shells. im thinking 20 offset should be perfect. no i gotta figure that hole inner shell and outer shell. this aggressive offset is all new to me.
__________________
James- Phase 3 of make over in progress
  #6 (permalink)
Old 09-20-2009, 12:49 AM
Slimjimx701x's Avatar
Slimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to liveSlimjimx701x relies on Rep Points to live
Send a message via AIM to Slimjimx701x Send a message via MSN to Slimjimx701x
If you want GD measurements, I do not mind meeting up with you
7. Have fun!
__________________
Entertainment- Pioneer Avic-D3
Power- Blitz Throttle Controller (Thanks Dave), SHG_Mike inspired Airbox mod, T1R V2 muffler
Handling- Progress RearSway Bar w/Panducky bolts, T1r lower arm and rear strut bar, SPC Camber Kit, Falken Ziex ZE-912 w/ LS Meshes
http://www.fitfreak.net/forums/fit-j...ake-build.html
  #7 (permalink)
Old 09-20-2009, 03:24 AM
danielg's Avatar
Quote:
Tell me the specs now, what you're trying to accomplish, and do my best to help.
  #8 (permalink)
Old 09-20-2009, 03:25 AM
danielg's Avatar
Quote:
Do you have aftermarket wheels on your GD? When are you located and what's your schedule?
  #9 (permalink)
Old 09-20-2009, 03:44 AM
I'm OE ATM (LS Mesh, if the trade works out). As for the moment, I should be free on the afternoon of 25th, if everything goes to plan. If not OCT 4 around afternoon.
__________________
  #10 (permalink)
Old 09-20-2009, 04:14 PM
SD_MR_FIT's Avatar
i think its at 50 offset if not 55 but im pretty sure its 50. and the rim is 15x7 as it stand right now.
and i just wanna have a nice amount of lip to have that deep dish look and im going to be dropped on skunk2 pro c soon. figuring a stretched 195/50 tire will do right.
__________________
  #11 (permalink)
Old 09-29-2009, 10:02 PM
CamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to live
LE37 17/7.5 43 offset and i think 215 rubber... i forget... but its almoste flush and when i install my t1r coils it should be quite the slick fitment.... ill post pics next spring....
__________________
"volks just look so much better with brembo"
  #12 (permalink)
Old 09-30-2009, 12:31 PM
MugenAP2's Avatar
MugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to liveMugenAP2 relies on Rep Points to live
Daniel do you have any luck with what you are going to do with the front fender tab to be able to stop the rubbing? I have pulled my fenders and I don't know what I am going to do to pull the bumper out to stop the rubbing. There needs to be a way to connect the bumper and the fender while pulling them outward
  #13 (permalink)
Old 09-30-2009, 05:23 PM
Fit4Trav's Avatar
Fit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to live
Send a message via MSN to Fit4Trav
I love Aggressive wheels
Daniel you have to see how my new rears fit
__________________
REAL FRIENDS > CAR CLUBS
FROM SEMA:
Quote:
Originally Posted by Courtney Day
Offset is everything
http://autoimportcraze.com/
  #14 (permalink)
Old 10-05-2009, 02:28 AM
danielg's Avatar
Are you just going to add another inch of lip? Also what type of lips do those use? If they're not a standard BBS, OZ etc lip, you'll probably need to get some custom spun.
  #15 (permalink)
Old 10-05-2009, 02:29 AM
danielg's Avatar
Quote:
See above for x7.5 +40
  #16 (permalink)
Old 10-05-2009, 02:31 AM
danielg's Avatar
Quote:
Are you talking about the front tab that connects to the bumper? I'm just going to chop it off, drill some holes and make a bracket. If you can't wait, zip ties will hold until you can fab something up.
  #17 (permalink)
Old 10-05-2009, 02:32 AM
danielg's Avatar
Post in here with specs and what you did, and I'll add it to the top posts. Can't wait to see it man.
  #18 (permalink)
danielg's Avatar
OK everyone's been answered. Sorry I've be laggin guys, I've been busy with real life.
  #19 (permalink)
Old 10-16-2009, 04:57 AM
chinkyy's Avatar
chinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to livechinkyy relies on Rep Points to live
how would u induce rear camber for the GD?
  #20 (permalink)
Old 10-23-2009, 11:39 AM
danielg's Avatar
shims or the washer trick
Reply
Tags
aggressive, civic, collection, fit, fitment, flush, honda, offset, thread, trick, washer, wheel
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
In-dash navigation fitment Swimmer Boy Fit I.C.E. 1 08-31-2009 05:57 PM
In-dash navigation fitment Swimmer Boy Fit I.C.E. 0 08-31-2009 01:02 PM
Unofficial? Honda fit forums. comptrekkie Site Feedback and Suggestions 52 04-27-2009 01:02 AM
Unofficial FAQ igniter updates... TeGGeR® Other Car Related Discussions 0 06-28-2005 10:30 PM
Ignition updates to the Unofficial FAQ TeGGeR® Other Car Related Discussions 44 06-06-2005 04:11 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
