Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes > 2nd Generation GE8 Specific Wheel & Tire Sub-Forum
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 10-16-2009, 10:42 PM
andyb is an unknown quantity at this point
wheel spacers
I'm interested in getting wheel spacers on the rear axle of my Fit. My plan to to get the stock wheels flush with the fenders after lowering. I'm thinking of either 17 or 20mm.
Anyhow, does anyone know the thread pitch of the stock Fit lugnuts? I will need to get longer wheel studs so it would be helpful to know which thread pitch to get.
Thanks!
A
Sponsored Links
  #2 (permalink)
Old 10-16-2009, 11:37 PM
FITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to live
Bolt Pattern:4/100
Center Bore:56.1
Thread:12x1.5
I would not recommend spacer but adapter. Please see link below.
25MM WHEEL SPACERS ADAPTERS INTEGRA DEL SOL FIT CIVIC:eBay Motors (item 150364110444 end time Nov-03-09 16:51:10 PST)
  #3 (permalink)
Old 10-16-2009, 11:54 PM
Thanks for the link. I think the difference is semantic. Can anyone confirm that 12x1.5 is the correct thread pitch?
A
  #4 (permalink)
Old 12-25-2009, 09:16 AM
Josephkao is an unknown quantity at this point
Is 25mm too big for stock 16" rims?
  #5 (permalink)
Old 12-25-2009, 03:24 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
Will I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to liveWill I Am fit. relies on Rep Points to live
^ You need to change to an extended lugs, safest spacer you can run is 5mm the most on stock lugs IMO..
__________________
Blackout your headlights PM me....
  #6 (permalink)
Old 12-25-2009, 06:10 PM
petwhookie's Avatar
petwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to livepetwhookie relies on Rep Points to live
Quote:
A
Yup 12x1.5
__________________
Domokun Crew Memeber #10 - NorcalTuners
  #7 (permalink)
Old 12-30-2009, 11:26 PM
Perrenoud Fit's Avatar
Perrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to livePerrenoud Fit relies on Rep Points to live
Smile Spaced Out
One of the things I've noticed is the wheel placment in the inner fender, it looks too far in. So I did some research and it was 50/50 the biggest fact was use a bolt on spacer and not a slide on over the studs. Retorque the lugnut (i'm going with 90 ft/lbs not 80) after driving for 2 days. MzFiT is gettin 25mm out back and 15mm up front, the wide track look. Ichiba has the best product with the V2 and I got all 4 corners for 240.00 shipped. If it puts the tires out to the fenders it'll do what i'm look'n 4 and save the price of new rims$. So when i do this i'll post before, during and after pix and see if it helps or hurts the handeling?................
C-ya'll
__________________
Perrenoud Fit
  #8 (permalink)
Old 12-31-2009, 12:20 AM
solbrothers's Avatar
solbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to livesolbrothers relies on Rep Points to live
Send a message via AIM to solbrothers
i ran spacers for a while. 25mm bolt on spacers. worked fine for me
__________________
-matt
Quote:
Originally Posted by keepitpg View Post
cant disagree with solbrothers
  #9 (permalink)
Old 02-25-2010, 09:58 PM
jookybanana's Avatar
jookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to livejookybanana relies on Rep Points to live
run bolt-on spacers, they are easier to install than the ones with longer studs
i have 10mm bolt-on spacers on my rear and it doesn't seem flush yet, i think 10mm up front and 20mm rear will make the stock rims perfect
Reply
Tags
12x15, 2009, 561, 5mm, fit, fitfreak, forums, ge8, honda, ichiba, rear, spacer, spacers, tire, wheel
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wheel Spacers MIAMIFIT 2nd Generation (GE 08-present) 32 Yesterday 02:01 AM
The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!) Illusive Fit Shoes 90 02-28-2010 11:42 PM
Suspension Theory cojaro Fit Suspension & Brake Modifications 31 02-15-2010 06:13 AM
Sticky?: Suspension Theory (extended) cojaro Fit Suspension & Brake Modifications 11 02-14-2010 12:31 PM
Wheel Spacers? KoolMikeSki Fit Shoes 11 08-09-2009 09:15 PM
Go
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
