Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes > 2nd Generation GE8 Specific Wheel & Tire Sub-Forum
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 10-19-2009, 11:15 PM
runbikerun's Avatar
runbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to live
205/50/16 Goodyear Fuel Max Ride
Hey, A quick update. I put some Assurance Fuel Max 205/50/16s on my 09 Sport stock wheels. So far they are pretty good tires. The ride is smoother than stock at 35psi. I can't comment officially on the mileage as of yet because the cold weather and has been playing havoc on my first couple tanks of gas with them. I do think I might be adding 1 mpg. I'll post when I get some accurate, consistent reports. I know these are more of a Touring tire but I really feel the sway that they give at highway speeds is terrible. Would a wider rim (7") help this? I upped the pressure to 40 psi and the sway seems better but I'm not sure if they feel that safe at 70mph. Anyone else have this issue?
__________________
09 Crystal Black SPORT
Sponsored Links
  #2 (permalink)
Old 10-20-2009, 12:25 AM
neil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to liveneil patrick harris relies on Rep Points to live
do they not feel more stable than the stock tires? i would have guessed since it has a much wider contact patch that it would. perhaps you have too much pressure in your tires causing the tire to bulge in the middle and defeating the wider surface area? is the sway really better when you put in more pressure or was there just less wind when you were driving the second time around?
  #3 (permalink)
Old 10-20-2009, 12:52 AM
runbikerun's Avatar
Quote:
I will take the pressure back to 35 than 33 and check the difference. It really became apparent when i would change lanes at 70mph. It felt like the care would rock back and forth. I am still trying to find out if a wider rim would change this?
__________________
  #4 (permalink)
Old 10-20-2009, 12:59 AM
Quote:
a wider wheel won't give you a wider contact patch if you're running the same size tires, UNLESS the tires are technically too big to fit on your current wheels in the first place. if they're too wide for wheels, the outside tread may not be making contact w/ the ground. i can't really verify whether or not 205s are too wide for a 6.5" wheel.
  #5 (permalink)
Old 10-25-2009, 07:39 PM
tdesi420's Avatar
tdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to livetdesi420 relies on Rep Points to live
205's are not too wide on a 6.5" rim. i am running that setup currently on my GE8 with 15" rims. Car feels more stable than the stock 185's on the stock 16" rims, especially on a windy day.
__________________
New car: Blue Sensation Pearl 2009 Honda Fit Sport 5AT -12/24/08
Mods so far: 6000k Bixenons HIDs, 3000k HID Fogs, 35% sides & 20% hatch tints, JDM Non-LED tails, Red steering wheel inserts.
Rims: 15"x6.5" Konig Britelites (12.6 lbs/rim) & 205/50/15 Kumho AST tires.
Previous car: Milano Red 1999 Acura Integra LS
-Bought 12/17/02 Totalled 12/12/08
Before that: Cayenne Red Pearl 1998 Acura Integra GS
- Bought 07/21/01 Stolen 12/15/01
  #6 (permalink)
Old 11-06-2009, 06:46 PM
huisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to livehuisj relies on Rep Points to live
Quote:
A 6.5" rim is fine for a a 205 tire. All Ford Focus' with the 16" wheels had 6.5" rims, and they all ran 205/50/16 from the factory.
  #7 (permalink)
Old 11-06-2009, 07:14 PM
Chad T's Avatar
Chad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to liveChad T relies on Rep Points to live
Brand new tires can be a little squishy for the first few hundred miles too. Maybe see if they get better with a little wear.
__________________
2009 MT Base Fit
1986 Shelby GLHS #088
Reply
Tags
16, 2007, 205, 20550, 2055016, 50, assurance, fit, fuel, general, goodyear, honda, max, rim, sport, tires
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fuel Pressure Gauge YeeFit Fit Forced Induction Forum 0 02-23-2009 01:01 AM
"Battle of two fuel Sippers" Scaldy 2nd Generation (GE 08-present) 6 02-07-2009 02:52 PM
Sticky?: Suspension Theory (extended) cojaro Fit Suspension & Brake Modifications 10 10-18-2008 01:38 AM
Fuel Theft on HONDA FIT! Rayzel General Fit Talk 36 01-28-2008 03:32 PM
Fuel system for Bank One too Lean code jbourgeois Other Car Related Discussions 5 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
