'13 base Fit : Go with the General Altimax Arctic w/ round studs 185/ 65-15 @
'13 base Fit : Go with the General Altimax Arctic w/studs 185/ 60-15 @
$82 each or the Nokian Hakkapeliitta 8s' 175/65-15 that have hexagon studs at $125 each ? Installation included for the 8s' ( $500 ) , not so for the Arctic . Additional $65 for mount / balance costing close to $400 installed .
Do you want a studded or a non-studded setup? Also, do you have a second set of wheels to mount these on, or do you plan to swap them back and forth each season on one set of wheels?
If I were shopping in the $400-$500 price range, I would order a set of 14" Altimax Arctics mounted and balanced on steel wheels from Tire Rack (which is actually what I did). You can also have them add/install studs if you'd like for a relatively small charge.
hankim68
38
02-21-2012 02:46 AM
britdevine
08-21-2011 09:56 PM
