Wheels rubbing in the rear
Old 05-02-2015, 04:00 PM
bati555's Avatar
I just got a new set of wheels 15x7 Advanti Racing Storm S1 and 195/55R15 General AltiMAX RT43 tires. The problem is, they rub pretty badly when there are people sitting in the back.
What is the cause of the rub? I heard somewhere it is a bolt in the rear that I need to just cut a couple inches off of. Where do I find this?
Thank you for your help.
Old 05-02-2015, 04:09 PM
doctordoom's Avatar
Supervillain
What's the wheel offset?
Old 05-02-2015, 04:32 PM
bati555's Avatar
35mm offset. The fronts don't rub as far as I know. It's the rear wheels on big bumps or if theres anyone sitting the back, at every bump and turn lol.
Old 05-02-2015, 05:03 PM
doctordoom's Avatar
Supervillain
It's probably the bumper tabs in the rear. Just get down and look up in the wheel well, on the outboard side. It should be obvious if you get down and just see what's the first thing your tire would hit when the suspension compresses.
Old 05-03-2015, 05:14 PM
bati555's Avatar
Thanks I'll check that out. Also my car's GD.
Old 05-06-2015, 12:26 AM
john21031's Avatar
Your wheels are too big. This the reason to use the OEM, they are designed for the suspension and the wheel well size.
Would you be surprised if you installed wheels from Honda Pilot and find them rubbing the fenders?
Keep in mind that you might die or kill someone when that wheel explodes on the freeway in a turn. I highly recommend putting back the proper size wheels and tires.
Old 05-06-2015, 03:29 AM
bati555's Avatar
Haha take it easy man, it's just a little rubbing when a passenger is in the back. It's the contact of the wheel(not the tire) with something else. I just don't know what it is and will check it out this week before driving it.
Old 05-06-2015, 08:55 AM
Aarron_M's Avatar
Wow, that was a hell of a jump. From rubbing to explosions and death.
Old 05-19-2015, 03:49 PM
mahout's Avatar
besides your wheel offset being too little (45mm is minimum) if the wheels and not tires rubbing you have a serious problem that you better find quickly. the tires should be rubbing the fender but if its not, its not simple.
Old 05-29-2015, 11:24 AM
cbgoding's Avatar
I've been running 25 offset and 8" wheels for a year and a half. Pull your fenders, you'll be fine. Rub isn't fun, but you're unlikely to pop a tire. Just drive slow and don't take passengers til you get the fenders pulled. I am 99% sure it's your tires and not your wheels rubbing. Get your car on jack stands, remove your rear springs (it takes like 15 minutes) and jack your trailing arms up until it rubs. Find point of contact. Fix it.
Old 05-29-2015, 08:00 PM
bati555's Avatar
Thanks for the reply. How did you exactly pull your fenders? Do I just cut through the plastic fender that is touching the tires?
I definitely haven't had people in the car and it's a good excuse not to. I know I need the backseat some days though.
Do you have any photos or steps recommended in doing this? I just have a hard time visualizing how pushing the trailing arm would indicate the contact pt. Thanks again.
Old 05-29-2015, 08:06 PM
cbgoding's Avatar
I'm rotating my tires tomorrow, I'll drop the springs and make a video.
I'll show you what I did for pulling the fenders too.
bati555's Avatar
Awesome i look forward to it
Old 05-31-2015, 11:16 PM
cbgoding's Avatar
Sorry it took an extra day, but here ya go. If you need clarification on anything, let me know. If not, sorry I kinda babied you through each step in the video.
KyleB2706
12-14-2017 11:59 AM
Kingjooz
12-11-2012 09:12 AM
Sleep_DEPRIVED
11-15-2009 03:54 AM
MarkyMark
11-07-2007 08:50 PM
Nightson
01-11-2007 05:09 PM
Quick Reply: Wheels rubbing in the rear
