View Single Post
  #14 (permalink)
Old 05-03-2008, 01:36 PM
leonine's Avatar
leonine leonine is offline
leonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to live
if you live in a warm climate you can go with the odyssey or the braille 2015. i would recommend the braille because the specs seem to perform better. the odyssey only has 220 cca acording to their website so imo it would suck in the winter months. that is half of what the braille 2015 has and i had that one. it didn't last. if you are living in winter climates the only one i would get is the braille 3121 which although weighs the same as stock it puts out much more power. braille also recommends this battery for engines that are boosted. here is what i have found
Oydssey (taken from their website)
PC 680 / PC 680mj Specs:
  • 680 cranking amps for 5 seconds (i am assuming these are PCA)
  • 595 cranking amps for 10 seconds
  • 525 cranking amps for 20 seconds
  • Short circuit current over 1800A
  • 17Ah
  • 25 minute reserve capacity with 25amp load
  • CCA - 220 (Is this important?)
  • Female brass terminal w/M6 SS bolt
Braille 2015 (this is the one i had until recently)
Model Name: B2015 - All Season Battery
Recommended Use: Winning Races!
  • Use this battery to get that last tenth of a second from your times.
  • Difficult and small engine location needs.
  • Can be used in pairs for custom application.
  • Competition and lightweight daily use in small displacement engines.
  • Excellent starting and running battery.
Not Recommended For:
  • Extreme Cold Climates
  • Extreme Audio Applications
  • Ultra High Compression Motors Running Aftermarket Ignitions w/o Alternators.
Specifications:
Casing: Polymer Plastic
Weight: 15 lbs
Length: 6.8
Width: 3.4
Height: 6.1
Pulse Cranking Amps: 1067
Cranking Amps: 574
Cold Cranking Amps: 425
Amp Hour Rating: 21
Braille 3121 (this is the one i have nnow)
B3121 No-Weight Extreme Battery Specs
Weight: 21 lbs
Length: 6.6
Width: 5.2
Height: 6.8
Pulse Cranking Amps: 1380
Cranking Amps: 742
Cold Cranking Amps: 550
Amp Hour Rating: 31
Warranty: 1 Year Free Replacement / 2 Year Limited Pro-Rated Extended Coverage
Recommended Uses:
Premium Luxury Vehicles
Extreme Engine Builds – High Compression, Supercharger Systems, Large Cams, Underdrive Pulleys & No Alternators
Extreme Audio Builds – Multiple Amps, Subs and enough wiring for a small city? You need this battery! Extreme Cold Climates – Daily Driven or Stored Vehicles
Custom Cars and Vintage Vehicles – No Acid to Spill protect and enhance your vehicle!
Any vehicle you don’t want to look or perform better!
__________________
Check out the transformation over the past 3 years.
http://www.facebook.com/album.php?ai...7&l=cd5f9d6b0a
