Nice writeup!
I had these shocks installed into the rear of my Jeep Cherokee to increase payload and keep the back end from sitting down on my larger tires. I had mine connected to an air hose which ran to a filler cap drilled through the rear bumper as well. I usually kept it around 50-60psi and loaded it upto about 130psi at the gas station air when I had excessive payload.
I found my ride height could be adjusted up to about 2" depending on the amount of pressure, I am curious, when you increase the pressure how is the ride height for the Fit?
Cheers,
__________________
For a jolt of pure awesome... just click the sugarphreak button!
