Quote:
Originally Posted by Sloto200
i got it installed... had to put the sensor rubber boot right up against the silicone boot that mounts to the TB. I am going to have to try and get some slack in the wires as the sensor is sitting at an angle slightly because the wires just arent long enough.
You might not have the boot pushed as far as it will go on the TB. There is a small tab on the TB that the boot should sit flush with.
All it takes is just pushing the boot on a little farther to create enough slack to eliminate that angle on the sensor.
ez
