Sponsored by:
Sponsored by: CARiD
MP3 CDs...any tricks?
Old May 11, 2008 | 04:07 PM
dafit's Avatar
The wife got a new fit this week. This is good news and bad news. The good news is we have a great, fun, sporty little car with great MPG.
The bad news is that I inherit the minivan. ;o)
Anyways, this is the first car we've ever owned with MP3 CD support.
I've burned a couple of CD-Rs on my XP box and was sure to 'close CD' so it can be read on other systems.
Alas, these keep getting spit out of the Fit as 'BAD DISK'.
These disks are readable just fine on my MacBook and other computers in the house.
Am I missing something obvious to get these disks to work? Does the Fit stereo prefer some specific CD-R or CD-R format?
Old May 11, 2008 | 04:39 PM
Padraic's Avatar
Which program did you use? I would recommend using Nero to burn the discs. It is one of the best burning programs out there. It is also readily available for download on torrent sites. Not that I would advocate that sort of thing.
Old May 11, 2008 | 04:46 PM
dafit's Avatar
Ya know, I'm not even sure. I just drag-to-disk and EJECT it to close it...umm...let's see...looks like Roxio.
Should the particular software matter? Seems a burned disk is a burned disk. I'll trying making one on my Mac later and see if that works any better.
Old May 11, 2008 | 05:04 PM
Kelmar's Avatar
Frequent FitFreak Poster
Did you burn it as an MP3 cd or a as a data cd?
Old May 11, 2008 | 05:16 PM
dafit's Avatar
ah! I guess that could be the issue. It's a data CD. I assume that's what an 'mp3 cd' meant. Is there such thing as a 'mp3 cd format'?
Old May 11, 2008 | 05:18 PM
dafit's Avatar
Well, Wikipedia seems to say that 'mp3 cd' is just a data cd with mp3 files:
MP3 CD is a term used to refer to compact discs (usually CD-R or CD-RW) that contain MP3 files. Discs are burned in data mode
Anyone know the manufacturer/model of the stock CD player? Maybe there's some picky thing about this model.
Old May 11, 2008 | 05:58 PM
JDMchris.com's Avatar
I run THIS
I use iTunes to burn all my CDRs. Never have a problem.
Old May 11, 2008 | 07:11 PM
suketoborudo00's Avatar
I use Nero.
Data CD setting, drag and drop, I don't have to finalize the CD either.
Burn using a CD-R
It works just like that.
You can trial test Nero here, there's a bunch of different versions.
HTML Code:
http://www.nero.com/enu/downloads.html
Old May 11, 2008 | 09:37 PM
seeremlive's Avatar
Do you have the Base Fit or the Fit Sport? Only the sport has the MP3 CD playback. If you have the base Fit you can burn a mix cd using Media player built into Win XP.
Old May 11, 2008 | 11:41 PM
pwnstar's Avatar
yea i was gonna ask the same thing Base or sport becouse the sport is the only one that suports WMA MP3 the base dose not
Old May 12, 2008 | 03:14 PM
rawrItsJello's Avatar
oo i just had to ask.. does the base model have mp3 cd playback? didnt see it on the cd deck...
Old May 12, 2008 | 04:08 PM
seeremlive's Avatar
If you have the base, nope...
Only the Sport has MP3 CD playback. It also supports WMA (Windows Media Audio)files.
Check this link near the bottom of the page
2008 Honda Fit - Specifications - the Official Honda Web Site
Old May 12, 2008 | 04:56 PM
Injundon's Avatar
Are by some odd chance burning them onto DVD-R's like my wife did ... It should work fine with a CD-R birnung it just as a data disc. Do your MP3 CD's play in other devices?
Old May 12, 2008 | 05:52 PM
gimme's Avatar
Master FitFreaker
i used to have that problem. i use nero and create an image/data disc. it reads the albums as file folders. i average 10 albums per disc. pretty neat........then i got my ipod
Old May 13, 2008 | 06:52 PM
dafit's Avatar
To clarify, we have the fit sport, so yes, it has MP3 CD capabilities. I also want to burn an actual MP3 CD, rather than an audio CD (so iTunes doesn't seem to be a candidate).
As it's my wife's car, I haven't had a chance to get back in it yet, but will try and get Nero and see if that solves the issue. Thanks for all the tips!
Old May 13, 2008 | 07:05 PM
JamesBizzle's Avatar
I, like Chris, also use iTunes to burn my CDs, AND ITunes can be used to burn MP3 Cds. All you have to do is go into Edit at the top of the screen, chose preferences, select the "advance" tab, then select the "burning" tab, click on the MP3 option and then press ok... you'll now be able to burn MP3 CDs using your iTunes software.
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
Originally Posted by suketoborudo00
I use Nero.
Burn using a CD-R
HTML Code:
This is the best and easiest way, any burning software you will have an option for
A) Music CD
B ) Data CD
--- To make an mp3 cd to work in the Fit choose Data, and you can just drag and drop music folders then burn it. Works as easy as that. You can PM me if you have any questions.
Old May 28, 2008 | 10:33 AM
Fit_61's Avatar
MP3 program for the Fit
I would highly recommend Ubuntu or Kubuntu Linux for ripping or burning CD or DVDs. K3B is an outstanding CD program that will let you make digital duplicates of CDs, etc. and even work with MP3 files.
Now if I only get a Fit Stereo what would work the AAC or OGG audio files...
Old May 28, 2008 | 11:16 AM
hondaf1racing's Avatar
are any of the files copyright protected? I had that problem when I was burning the files onto CD and 10 files were had DRM, the whole disc wouldn't play.
Old May 28, 2008 | 11:51 AM
GD3-Fit's Avatar
I <3 SPOON
x3 this works for me with no problems
you other guys are thinking too hard
use limwire to dl music
itunes to burn mp3 cd
it's very simple
nero is also very good
Itunes Mac and WIndows
Apple - iTunes - Download iTunes
if you still have problems let us know
-Ricky
