View Single Post
  #142 (permalink)
Old 05-15-2008, 06:45 PM
suketoborudo00 suketoborudo00 is online now
suketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to livesuketoborudo00 relies on Rep Points to live
Quote:
Originally Posted by Fray Adjacent View Post
Sweet! My ScanGauge is in my grubby little hands! I'll plug it into the car when I go get some grub later.
Any tips on how to get it going? The manual doesn't break it down into sections... but I'll give it a read anyway.
setup the scangauge with these settings
engine: 1.5 Liter
engine type: gasoline
fuel cutoff: mine is at 17 (but scangauge manual says to add 4 to the TPS gauge gives you when the foot is off the throttle. so for me when the foot is off the throttle, TPS reading is 13. so 13+4= 17 for the fuel cutoff)
tank size: put it at 10 gallons at first. There is a section in the manual that tells you how to adjust to the correct tank size on your next fillup.
I think those are the main ones you need to get it started, i missed a few because i'm going off memory
