View Single Post
  #24 (permalink)
Old 05-18-2008, 08:37 PM
wagonsir wagonsir is offline
wagonsir is an unknown quantity at this point
Quote:
Originally Posted by mahout View Post
Measure your read width and if it is less than 6 and 1/8" inches I'd say you have a better than average chance of making it not rubbing.
According to Bridgestone, the tread width of the P195/50R15 RE-01R is 7.2 inches. Thus, I sure hope you meant 7 1/8" instead of 6 1/8". I will try to get to Bridgestone and measure the tread width myself tomorrow.
PS where are you putting the camber bolts on the rear? I don't think you'll need them anyway front or rear.
You are right, of course, The camber bolts only affect the front. I was going to get alignment shims for the rear. The stock rear camber already has negative camber (1.3 to 1.5 degrees?), so I thought I'd just get a 0.5 degree shim. Although, I'm not clear if the shims increase or decrease camber.
